Hello...and a quick question.
Results 1 to 8 of 8
    Hello. My name is Bob, and I'm new here. Just a piddling little welder, haha. I also had a quick question. I'm looking at an ESAB Multimaster 260, but in doing my research on it, the manual says that it needs a 90 amp breaker on it, even though it says plainly that it would peak at 52 amps at 230V. Is this true, or am I missing something? I've never heard of doubling amps for a breaker, and it doesn't make any sense to me, but I'm far and gone from being an expert on this. Thanks very much, all!
    Mar 2005
    Under a Rock
    Re: Hello...and a quick question.
    Quote Originally Posted by Bob the Blacksmith View Post
    Nice machine.
    pretty sure that should be a 60 amp breaker not 90
    maybe it's a misprint.
    Hypertherm PM 45
    1961 Lincoln Idealarc 250
    HTP 221
    Apr 2019
    PNW
    I just looked it up, and the manual does call for a 90 amp fuse for 208V and 230V.
    But if it's only drawing 52 amps, I would agree with JohnT that all you should need is a 60amp breaker.
    Just say, Know.
    Los Angeles
    The manual states 90amp Fuse, not a 90 amp CB.
    I don't know the equivalent CB to a 90amp fuse but the Circuit Breakers are usually smaller.
    MM211 (Sold)
    Miller 125c Plasma 120v
    Los Angeles
    Miller has this in their manuals as they too list fuses in their electrical hook up section.
    *choose a circuit breaker with time-current curves comparable to the recommended fuse.
    MM211 (Sold)
    Ooh. I just read it as the same thing, haha. That does help to make more sense of the issue at hand. So, I'm assuming the "time-current curve" is in regards to time between a surge or something and the breaker tripping? You'll have to forgive me...I'm not electrically inclined.
    Los Angeles
    Pretty much.
    Fuse can be fast acting, normal and slow blow.
    Your general CB is basically a slow blow and acts as you mentioned.
    The 60amp circuit breaker recommended in the other post will suffice.
    MM211 (Sold)
    Huh. Learn something new everyday, haha. Thanks you all so much for your help!
