Straight edge cut offset
Results 1 to 8 of 8
    What is the offset to be figured when cutting 3/16 with a straight edge on the 45xp? This is with the standard consumable, not the fine cut. Thanks
    Re: Straight edge cut offset
    Make a cut then measure off the strait edge.
    Quote Originally Posted by bellaireroad View Post
    I am sorry but if you really need help figuring this out you might want to rethink using the plasma torch.
    Thanks, I thought someone might know before I did this....going to get some stencils CNC cut, and wanted it to be precise
    Oct 2007
    New Hampshire
    I just measured a set of hand torch consumables in my shop. The edge of the nozzle orifice to the edge of the shield (which is designed to drag along a straight edge or template) measures .200". Keep in mind if you cut slowly the kerf will get wider, cut fast and it will get narrower. Use .200" offset and you will get pretty close for hand cutting. Before you pay someone to cut 26 stencils you may want to experiment a bit with your technique to see how much offset you will get. Jim Colt
    Thanks!
    Thanks, I did play with it today, and got .1875
    Got a couple of stencils made to cut these ovals from flat stock. The 1875 offset worked good, maybe just shy too big, will probably try 1600 next time
