Mm200 CR1 Relay wiring
Results 1 to 3 of 3
    Oct 2010
    Indianapolis Indiana
    Got a mm200 in today.
    Sn JB555....
    Cr1 is completely missing.
    I suspect it had the old open style relay, and someone thought they could install the new enclosed style "when they got around to it."
    Problem is, the wiring diagram I have, does not match the service manu al for a newer mm200. (Tells you what wire is from what COMPONENT)
    I have the following wires:
    #32
    #3 (pair)
    #24
    #1 (pair)
    #22
    Help please....
    Miller Dynasty 200DX
    Miller Spectrum 250D
    Miller Millermatic 200
    Bunch of old blue dinosaurs....
    Oct 2010
    Re: Mm200 CR1 Relay wiring
    From what I can tell on the unit's wiring diagram....
    32 is 24 volts
    16 is plg2 or cr1
    21 is Cb1
    3 is plg2 or main contactor
    24 is SR1
    1 is fan motor or 115vac fuse
    22 is C3 or R1
    None of this matches the service manual diagram as pictured
    Oct 2010
    To anyone needing help on this:
    32 is A or B pole
    16 is A or B pole
    21 is common, same side of relay as 24
    3 is normally open, same side of relay as #1
    24 is normally open, same side of relay as 21
    1 is common, same side of relay as #3
    22 is normally closed
