SA200 Oil Pressure
Results 1 to 14 of 14
    Oct 2008
    Madison GA
    SA200 Oil Pressure
    Early 70's SA200 Continental F163
    After warm-up the oil pressure is running around 10 psi at idle (consistent on two different gauges)
    The engine doesn't smoke of have blow-by while welding
    Continental manual says minimum 7 psi at idle
    Is this is to low for long term reliability?
    Jan 2016
    northeast USA
    Re: SA200 Oil Pressure
    whats the pressure when cold? my sae 400 doesnt drop but a few pounds after warmup and stays around 30psi
    ROCKVILLE ,,VA
    Correct with minium on 7 psi and it 30 to 40 max high pressure,,, you can increase pressure by adding up to 4 washer under relief valve hex cap it located under carb side of block near end of the vent breathing tube,, thinking used 5/16 s/s steel washer? or 1/4"? if got your manual the organe manual is on page 69 the white and red manual it on page 71,,so try get your max pressure up 35 psi range would be good
    Oct 2008
    Madison GA
    Thanks for the replies
    Charlie I did find the details on page 69(grainy online manual).
    Got a 4 year old taking my extra time right now but I'll report back the first of the week.
    Oct 2008
    Madison GA
    Got some time and much thanks for the help
    Added four 6mm stainless steel washers and picture shows the results
    The second picture shows the location of the relief valve (1" plug, center of block behind the carburetor)
    ROCKVILLE ,,VA
    Good ,,,what get high idle?
    Oct 2008
    Madison GA
    That is on high
    Low idle drops less than 5 psi
    Less than 5psi at low idle (900-1000rpm) is not a good sign. As you've already stated, Continental spec is 7psi min at engine idle (600-1000rpm).
    I'd have to say either the oil pump or main/rod/cam bearings or all have excessive wear.
    Save Second Base!
    Where are you checking the pressure? Did you install an aftermarket oil filter? If so, which one?
    Save Second Base!
    Oct 2008
    Madison GA
    Thanks Duane
    I've checked two ways - original gauge on left side of block replaced by an owner installed a new NAPA gauge in the faceplate. New gauge plumbed in the same hole. Pressure was consistent between the two.
    Oil filter is original 1050 upside down configuration.
    Machine came to me not running having set for many years based on the rotten gas.
    I got it running and welding and owner upgraded wiring, auto idler, and gauges
    Engine does not have exhaust smoke, blow-by, or leaking seals.
    Oct 2008
    NorCal
    Should I read that as 5 psi at low idle, or 5 psi less than your photograph at high idle of 26 psi?
    Miller Dynasty 350
    Miller XMT 304
    Oct 2008
    Madison GA
    To be clearer, at low it drops less than 5 psi to about 25 psi
    Running speed is just under 30 psi (each mark on the gauge is 5 psi and the camera is at a slight angle).
    Oct 2008
    NorCal
    Quote Originally Posted by KC51 View Post
    Looks like you are right on spec, Run it!
    Miller Dynasty 350
    Miller XMT 304
    Obviously I misunderstood your description and as crab fisherman stated, run it.
    Save Second Base!
