Really thick steel TIG weld
Results 1 to 23 of 23
    Jul 2018
    Need to weld this 2” rod to this 1” thick plate. I’ve never welded anything this thick before, and not sure if my 200A Everlast is up to the task. Got a 26 water cooled torch.
    I’m thinking doing this with many many passes with a lot of cup walking.
    I know TIG and gas, but I’ve never learned any other welding process.
    You guys think this is doable with a 200A TIG?
    Apr 2010
    Re: Really thick steel TIG weld
    Andy Somogyi
    Quote Originally Posted by Andy Somogyi View Post
    Need to weld this 2” rod to this 1” thick plate . . .
    What is: the material, the weld joint configuration, and the
    utility of the final product.
    What it does determines weld joint design suitability, the
    size of the weld, - and how much Amp. H.P is required . . .
    Opus
    Jul 2018
    Andy Somogyi
    Opus
    The plate is hot rolled, and the rod is cold rolled mild steel. Using ER70S6.
    This is going to be a adjustable angle plate on my milling machine to mill some custom parts. The top plate will be machined after welding.
    Sent from my iPad using Tapatalk Pro
    May 2015
    You can absolutely do this with a 200 amp machine. Just preheat the material to somewhere around 250° and have at it.
    Apr 2010
    Andy Somogyi
    The plate is . . . This is going to be a adjustable angle plate
    on my milling machine . . . The top plate will be machined
    after welding.
    If I understand correctly - your weldment is static = welds to
    hold position - and not subject to dynamic load/stresses . . .
    In load/stress applications - round to square - is a prohibited
    weld joint . . .
    This is the sanctioned cheat - and within a 200 Amp. machine.
    Don't weld in the crotch of the 'round to flat' - insert into the
    recess, small-flat-bars parallel with the length of the CR & HR.
    Judicially - skip weld [warpage] after thoroughly descaling the
    elements . . .
    HTH -
    Opus
    Bemidji MN
    I prefer 250+ amps with 1/8" filler rod on heavy metal, but your machine will do ok.
    With your limitations I'd likely use 3/32" rod.
    Don't forget to grind off the millscale.
    Airco 300 - Syncro 350
    Nov 2014
    PDX PNW
    You got plenty of amps. A root pass then a couple weave passes should get the job done. Unless your going to bevel the round stock then it would need some more passes
    Jul 2018
    Thanks for the info. My original plan was (a) in the attached figure — two fillet welds, with A LOT of groove filling. So is (b) better, with a pair of plates cut and fillet welded in?
    Hmm, interesting, I would have thought (a) would be a lot stronger.
    The actual load in this part will be very very low, however it’s going to secure a part during a milling operation, so it needs to be very rigid. My thinking is making them more solid as in (a) would dampen vibrations better than (b).
    But that’s just my gut, I’m an engineer in my day job, not a pro welder by trade.
    Andy Somogyi
    weld joint . . .
    elements . . .
    HTH -
    Opus
    Jul 2018
    LOL, yeah clean off the mill scale with TIG, I’ve definitely learned that’s kinda important
    I’ve fillet and groove welded 1/2” plate with this welder, root and multiple hot passes, I’ve found 1/8 rod at 190A works pretty nicely. Melts easy and penetration is good. Made a big difference when I moved up to a 26 torch, much more stable arc than the 17.
    Thanks
    Apr 2010
    Andy Somogyi
    Thanks for the info. My original plan was . . .
    You know [about] weld symbols - this is the meat - read the entire thread . . .
    https://weldingweb.com/showthread.ph...cking-with-TIG
    HTH
    Opus
    ps -
    If you are committed to welding - get this book . . .
    https://images.search.yahoo.com/yhs/...Gz8f05rePKolHL
    Buy used - any edition from the 12th. forward is good . . .
    Nov 2014
    PDX PNW
    That makes it a touch more difficult getting down in there but definitely possibly, just whatch the duty cycle on the welder
    It’s way less welding when using the plate and it won’t warp. It will warp the other way. I’d use the plate like in the drawling
    Jul 2018
    Ah ha, I see what you’re saying, it’s a very bad weld profile, particularly the root, in that it’s deep and narrow, thus prone to cracking. Makes sense, thanks.
    So, some ways around this I see are milling about 3/8” I.e. making a face, then welding. This welds a flat to flat, thus eliminating the deep narrow root pass.
    I’ll pick up that book, good info.
    I found a nice summary of weld profiles here
    https://m.lincolnelectric.com/en-us/...ldcracking.pdf
    Andy Somogyi
    HTH
    Opus
    ps -
    Mar 2012
    Australia
    For what your using this for I'd use the plate method, it doesn't have to be full pen to get the rigidity needed.
    Perhaps put a few decent 1/2 inch long tacks in the root where the round and flat meet before plating it out for a bit more lateral stability.
    Sent from my R7sf using Tapatalk
    Bemidji MN
    I agree with ttoks. Option b) has the potential for the most rigidity.
    In addition to the added plate material, the location of the welds provides greater leverage to prevent movement of the solid shaft.
    Mar 2019
    North & South America
    Why not stick weld it?
    Self-sufficient...to the end...
    Engineer and build it all
    Miller CST280
    ESAB EMP 235
    Abene
    Rockwell
    Atlas
    Fluke
    and the list goes on....
    Jul 2018
    Quote Originally Posted by Renaissance1 View Post
    Mostly because I’m not very good at stick, haven’t stick welded in a long time.
    Mount Tabor VT
    Somewhere between A and B. Lay 1/2" rod in the joint. Tack it often. Move around side to side, end to end. It'll distort a lot, It will then need to be machined flat again.
    SoCal-LA
    Sure it is doable. The machine is up to the task but your aircooled torch is going to complain as it is rated for 150 amps but you really want to weld at 200 amps as long as you can. You will have to let it cool many times and could loose your heat buildup but I have yet to melt the head off the torch. I have a thermal blanket to cover between passes or at lunchtime.
    This joint is called a flare bevel groove weld. Anyway two ways I have done this is preheat to some 400 degrees with a rosebud and drive a root pass in the root. Or weld the ends and baby the root passes in. Then a series of weaves like mentioned above.
    Anyway once you accumulate some heat in the weldment it should weld nice.
    Sep 2007
    Mesick Michigan
    I'd just run some 5/32" 6010 nice and hot in for the root. Then clean and weave a couple tig passes over that.
    --Gol'
    Aug 2016
    Michigan
    I was welding something about that size last night on my 330. Set at around 200 amps, 1/8 filler rod. It works fine once you get some preheat into the part. I think you'll be fine if you heat the parts up a little and give er hell.
    Miller Syncrowave 300(s)
    Miller 330 A/BP w/ WP-18 torch / WP-26 torch
    Miller CP-200 Haas / Kamp'd / CP-300 in process
    Homemade tig cooler
    Miller 30A /S-52E feeders
    Bemidji MN
    Quote Originally Posted by 86turbodsl View Post
    You got the amps, go 230-250 amps and let'er fly.
    Instant puddle, rock on with 1/8" rod and try for "mig speed"
    Plus, big amps can "eliminate mill scale cleaning"
    https://weldingweb.com/showthread.ph...cale-zero-prep
    Aug 2016
    Michigan
    I would have gone hotter, but I didn't have any bigger tungstens and I'm still on the air cooled torch. Can you say smokin?
    Sent from my LG-TP450 using Tapatalk
    Homemade tig cooler
    Bemidji MN
    Yeah, the big amps makes them hot for sure.
    Melted a couple 26 series torches before I went water cooled.
    Dropping the torch in a bucket of water works too.
    I draped mine over the Airco in the giant fan air stream, that method didn't cool fast enough for me...
