Drilling aluminum ?
Results 1 to 6 of 6
    Oct 2016
    Delavan WI
    Drilling aluminum ?
    Howdy, I need to drill some 5/8" diameter by 2 1/4" deep holes in some aluminum grade unknown but doesn't need to be welded just machine able with hand tools. So do you run the drill fast or slow? Twist drill in a budget drill press with, not horrible, rpm range. WD-40 as lube.
    Re: Drilling aluminum ?
    I would run it about 700 rpm, not really that critical. Put in about a 1/4" pilot hole to help hold the lube. ATF works good for lube.
    Aug 2018
    'ta town, KS
    Aluminum I would run as fast as your press will allow
    Mac
    Oct 2016
    Delavan WI
    Thank you!
    Like M J D says around 700 for a 5/8 hole should be ok at 2 inch deep some alloys can be pretty gummy so lube is good especially if you're drillin' a bunch of em'.
    Oct 2016
    Delavan WI
    700r's check, lube check.
