vulcan branded solid mig wire
Results 1 to 12 of 12
    any of you guys try the Vulcan mig wire? any good?
    SoCal-LA
    Re: vulcan branded solid mig wire
    Seems to be ok. Although I prefer Lincoln.
    Aug 2015
    Houston
    It burns ok, but for my Lincoln 180C the Lincoln wire runs better. It’s certainly not the worst wire out there, but I’m just a guy messing around in his garage. FYI the flux core is made in Italy and it’s not bad either.
    Learning to weld, one arc at a time.
    thanks guys, guess it won't hurt to try a 2 lb spool out.
    Quote Originally Posted by emeraldcoupe View Post
    Check online for coupon !!!
    Southern California
    It's worked about as good as any in my experience (have used about 7 or 8 pounds off the 10 lb roll). Made in usa Lincoln is (also) my preference but it's a very minute difference in arc characteristic. A quick way to test the metal's mettle is to Weld some samples and take the hammer to it - apparently torture does yield the truth!
    I haven't and wouldn't use it for anything critical but it has taken some cyclical loading abuse on some wheelbarrows used daily to carry over 200 lbs of drywall scrap over a construction site all day everyday for about a year.
    Use the 20% off vulcan accessories coupon (harbor freight coupon database website), and you can also use a 20% off coupon on another qualifying item, as well as a free item coupon in one purchase. Just cue them up on your phone and they can scan from there or you can read them the coupon number. The berger f-clamps and bremen locking pliers have been golden in my experience and quality for the 20% (sometimes 25%) off.
    Let us know how the wire works out as HF's quality can be all over the place from item to item.
    The welding youtuber that does proper HF wire/electrode tests side by side with major brands will have a TON of views in no time, I'm surprised no one has (project farm would be great if he did welding tests!). This is a question that comes up often on pretty much every welding/fab site.
    Brethren, Mi
    I was reluctant to try the house brand of China wire at the LWS,,, turns out to be some of the best I have ever used including L56. I went to get some more,,, they change it to WA or Radnor,,, I don't recall now but terrible compared to the cheap ****. I am not sure about the HF but give it a try. I wouldn't rule it out cause its cheap prior to investigation.
    Southern California
    I forgot to mention the vulcan mig wire also passed some bend tests a buddy of mine did with flying colors. Most things made overseas (which is most things) are probably welded with the cheapest chinese wire available, including towing/vehicle components! I don't know if it's more scary about what's holding your life in it's hand or more comforting that chinese wire can be competent.
    Jan 2009
    Sonoma County
    Some 15 years ago HF had a batch of blue 90A - AC flux core welders that were so bad that apparently every welder was returned. There was a huge quantity of those welders on Ebay in 'As New - Open Box' condition offered by a single liquidator. I was one of the customers who returned a welder. All it could do was spit. A year later I went back and bought the same model, it came with different wire and worked like it should. Bad wire doomed a whole season's sales of that model welder.
    The really awful wire was labelled K-NGS, by Kiswell. I looked for the agency they claimed had certified the wire as conforming to AWS spec. The 'certifying' agency appeared in Google only as a PO Box offering to issue a 'certification' of near anything for a fee after a written request - and a payment - from the vendor. In other words, bogus. HF has improved a lot since that bogus wire disaster.
    Here's a picture of the bad wire that I made at the time.
    http://nettractortalk.com/forums/att...9&d=1195979759
    HF MIG-180 with all the mods.
    Grizzly H8153 Stick/Tig Pulse 130/160.
    Wards PowrKraft AC-230. Stick & carbon arc.
    Jun 2018
    Knoxville TN
    Can't see the picture because I'm not a member there and not logged on.
    Jan 2009
    Sonoma County
    Quote Originally Posted by jfh View Post
    Sorry, I didn't realize the photos over there are limited. I uploaded it here.
    This is the flux core wire that came in the HF AC-90 welders for a time - a time when this HF forum was full of newbies asking 'How the heck do I make this thing work?' Me included. I could stick-weld fine with a big AC230 but when I bought the HF "mig" (flux) welder it was useless, nothing but spitting fiery blobs. At the time Ebay was flooded with those welders in As-New Open-Box condition.
    A year later with better wire included, the same welders sold then worked as expected and this forum calmed down.
    I see my photo date was 2007. HF has come a long way since then.
    I got a 2 lb spool of the 025 , I've used it to weld in some patch panels. seems to work fine, I don't notice any difference from the Lincoln wire I was using. i'm not a pro and don't claim to be, so results and opinions may vary
