Welding Table Design - Page 2
Results 26 to 37 of 37
    May 2017
    Re: Welding Table Design
    just saying then you got some Americans complaining about where they rest their feet on their welding bench
    If I had gold plated toilet seats I would complain that they were cold. That’s what Americans do. It isn’t new.
    Dec 2003
    Fairfield,CT
    i find it amusing some. in China often shop we called a garage door as they roll up garage door and do most of their welding work on the floor, abrasive saw on floor, drill press on floor, often welding on the ground and when they need room might be working on the side walk. their welding machine and most other equipment fits in a couple of plastic 5 gallon buckets. if something heavy i have often seen 4 to 8 guys using a pipe on their shoulders and a nylon strap as a portable crane even bring heavy stuff up the stairs
    I am not in Chiiiiinnnnnna. I am in USA and don't give a rats *** about Chiiiiinnnaaa. I am making a suggestion to where you would put your foot/feet to control your foot pedal and not complaining.
    www.tjsperformance.com
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    4' x 8' CNC Plasma Table
    Instagram: tjsperformance
    Dec 2003
    Fairfield,CT
    Quote Originally Posted by jeffrey.penfield View Post
    I built mine for many purposes, including TIG. It is 38 inches tall. My son is practicing aluminum TIG. Can you show pictures of your chair and table and where you set your foot pedal and tell me how tall your table is?
    Simply remove the lower crossbars in one opening. That is where you would put your chair and foot pedal. Not sure what the big deal is here people. I don't give a hang how your build your welding table but I am sure it will be figured out real quick if you are tigging and fighting with the chair, crossbar and foot pedal.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
    Jan 2006
    Sunny Phoenix
    Why not make a drop on top to cover your slats and take it off when you need the slats. I have also considered slats like your design with holes. I would make it so I could sit down and weld on it too if it were mine.
    May 2017
    Because a 48x48x1/2” top weighs 350 pounds
    Who gives a rats azz?
    They also weld with sunglasses and flip-flops
    that’s nothing to be proud of Tom
    Dec 2003
    Fairfield,CT
    My table top is 7 feet long and 3 ft wide and weighs almost 500 lbs. and is all open in the front. Built it in 2003.
    Dynasty 300 DX
    HTP 240
    HTP Microcut 380
    Hyperthem 85
    Bpt. Mill/DRO
  8. #33
    by a resevior in north central ar.
    deleted
    lincoln 125sp
    monkey wards 250 ac/dc
    miller 211 w/spool gun
    ahp 200 sx tig
    lotos ltp5000d
    of course duramax diesel
  9. #34
    Jul 2015
    what gauge metal would you use for the legs? trying to design a table and just want to know why i need a certain size before i purchase.
  10. #35
    I do most of my TIG welding sitting down.
    I actually made a different table specifically for sit down TIG welding. Its much lower and smaller than my other welding table
    Name:  small table.jpg
    Millermatic 252
    Syncrowave 250
    Purox Metalmaster
  11. #36
    When shopping for your top , check for drops or cutoffs. You may find that odd dimensional pieces maybe less money. Instead of a 36'' x 60'' you may find a 38'' x 64'' or something .
    Here's a table I made with a member when she was just learning.You may see some ideas you like.
    https://weldingweb.com/showthread.ph...ble&highlight=
  12. #37
    May 2017
    Don’t be particular about the the size of the top. You won’t be able to cut it with a saw to fit and if you use a torch it will warp. Custom cut tops drive up the price. I just bought a 48x48 x1/2” stock plate and it was nice and flat and square. Some people round the corners but I like using the edges for straight edges and the corners for right angles.
