Ranger 8 LPG
Results 1 to 4 of 4
Thread: Ranger 8 LPG
    Feb 2012
    Pa
    Ranger 8 LPG
    Hi every one.
    I have a chance to get a Ranger 8 LPG for free it was a rental years ago and hasn't been used. I hooked up a battery and a 33lb. LPG tank and it turns over and tries to fire but will not start.
    Any ideas on things to check will be appreciated.
    Thanks
    Jan 2011
    Hutchinson Kansas
    Re: Ranger 8 LPG
    Well the price is right.
    Check out the fuel system. Propane systems are not as difficult as most people think.
    There should be a fuel lock. Basically a solenoid that clicks on/off with the key.
    There may or may not be a filter and it may or may not be part of the fuel lock.
    There is a Regulator that uses engine vacuum to vary the amount of fuel fed to the engine. This is a lot like a torch regulator but continuously variable.
    Just like carbureted engines these parts can fail or get dirty. Check them all and clean if needed make sure you have fuel flow through the whole system.
    Be carful using solvents on the diaphragm and rubber parts. Dish soap is preferred.
    Feb 2012
    Pa
    Re: Ranger 8 LPG
    thanks propanehotrod I figured it out it has a low oil shut off and it was down about a half qt. It fired up and purred like a kitten now I just need to hook some leads up or a volt meter and see if it puts out any juice.
    Jan 2011
    Hutchinson Kansas
    Re: Ranger 8 LPG
    That's great.
    I have been looking for a good used lpg unit for a while now.
    Some guys have all the luck.
    Enjoy!
