Looking for a little info about hardfacing
Results 1 to 14 of 14
    Feb 2014
    Lebanon NJ
    So i have some jobs coming up that customers are in need of hardfacing and repairing some buckets. These are Cement plants so these loaders are loading stone and sand all day and everyday. I have not done much hardfacing in my time in the field as of yet so im looking at any help to get me going. ive heard to pre heat the base metal before welding and have also heard of putting the bucket in sand once completed to help slow down the cool down process. just looking for everyone else's input on how they go about this and any ideas that i can gather on how i can complete these jobs. What kind of rod everyone likes to use for these kind of jobs and things like that.
    Thanks welding web family
    Matt
    new york city
    Re: Looking for a little info about hardfacing
    sounds like you need rods for impact and abrasion. wearshield may do it.
    i.u.o.e. # 15
    queens, ny and sunny fla
    Soda springs,Id
    Stoody 31 was always my favorite. Read what polarity is required on the box. Adjust amperage as to whether welding flat, horizontal or vertical.
    Mike
    Hobart G-213 portable
    Feb 2014
    Lebanon NJ
    do you usually preheat the base metal ?
    NW New Jersey
    There are lot of different hardfacing electrodes.Best idea is to read the spec sheet for the electrode, and the application. Here's a link to the material I'm using now, Lincoln Wearshield BU(Build up). https://m.lincolnelectric.com/assets...ldBU/c7101.pdf
    Here's another one I've used before(for an Anvil), Lincoln Wearshield MI https://www.lincolnelectric.com/asse...ieldmi-eng.pdf
    I haven't done any large excavating equipment, mostly chippers, stump grinders, and plows. I'm sure somebody else can tell you what works the best on buckets. When I do preheat , I prefer using a Tempstik , just don't trust the IR gun some one bought for me. Because the work I do fits in the shop, most of the time I just use welding blankets to insulate while cooling.
    I'm sure others here will have more and better info for you , but its the weekend.
    Good Luck
    Feb 2014
    Lebanon NJ
    thanks for the info!
    Hellinois
    You want a severe abrasion rod. Last time I bought some it was McKay, which was my favorite brand. Unfortunately, ITW bought them up along with Miller and Hobart and offed the brand. I would look at Stoody website and/or call them.
    "Stick-man"
    Apr 2008
    NW ON Canada
    Your doing wear plate replacement on these buckets also? Wear plate replacement and hard facing usually go hand in hand. I’ve done quite a few large loader and excavator buckets over the years.
    Hard facing is what prevents wear. There are specific patterns to use for laying it on for sand abrasion, rock abrasion or a combo of both.
    I like to hard surface the cutting edges, sometimes the teeth/shanks and you can add some to the new wear plate as well.
    All I’ve used for wear plate welding is 70S6 mig and 7018 stick.
    Carbon arc air will make fast work of removing old worn out wear plate.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Feb 2014
    Lebanon NJ
    Not sure about the ware plating yet. im planning on meeting with the company that needs the work done this week and go over what they are looking for.
    May 2007
    SoCal
    I can tell you that sand will work, but make sure it is as dry as possible. Vermiculite does a good job also, and is as light as popcorn, just don't let it blow away in the wind.
    I have only just started using Stoody rod on an anvil surface myself. I used a 400* tempil stick along with an IR thermo to double check.
    Best of luck.
    Job 28:1,2
    Danny
    Apr 2008
    NW ON Canada
    I usually go with AR 400 wear plate. At least 3/4” thick for larger buckets on larger machines. On small or mini machines you can get away with thinner wear plate.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Feb 2014
    Lebanon NJ
    awesome thanks for the info guys
    Jul 2012
    This link is from heavy equipment forum, has some great bucket rebuilding pictures.
    https://www.heavyequipmentforums.com...ictures.23087/
    Feb 2014
    Lebanon NJ
    has anyone every had luck with forney hardfacing rods
