Miller diversion 180 not welding aluminum
Results 1 to 5 of 5
    Hi Welding Web,
    First post on the forum, desperately hoping I can get some assistance
    I have a Miller Diversion 180 that I use almost exclusively to TIG weld aluminum. About a month ago, it began acting up and I brought it in for repair.
    It welds steel fine, but when welding aluminum, it acts like there is not gas flow (although there is). It has been in for repair and come back with an entirely new motherboard (as it was under warranty) but is still doing the same exact thing. I feel like I'm going crazy. Does anyone have any recommendations?
    Delaware
    Re: Miller diversion 180 not welding aluminum
    Well apparently they didn't test it, take it back and have them test it this time.
    PDX PNW
    Welcome to the forum. Possibly bad gas?
    So many possibilities.
    Are you using pure argon?
    AC?
    1/8" or thinner?
    What filler variety?
    15 CFH argon?
    Very short arc?
    Hit it with enough current to form a puddle in three seconds or less. I had a Diversion 180. I found its duty cycle to be very low. Steel welded fine, it ran short of power with aluminum.
    Quote Originally Posted by tunnels12000 View Post
    Hi Welding Web,
    Are your using different collet/collet body? You really should pick up a portable gas flow checker to confirm gas flow to the torch. https://www.ebay.com/itm/Welding-Gas...53.m1438.l2649
    Could be a bad backcap, crushed collet, crack in gas hose, ect. But I also agree, the repair facility should have tested the machine.
