Advice on a weld
Results 1 to 15 of 15
    Aug 2019
    S. Central Wisconsin
    Advice on a weld
    I am going to weld a couple brackets on my RV steps to bolster them a bit. I am new to welding and after posting an after of my last project, I got a lot of creative criticism on it. Thanks all. I am learning. Anyway, I am not so much after actual welding advice but safety this time. Since the RV has a propane line running under the cabin via steel pipe, do I have to worry about it at all. I plan to remove the tank and then purge the lines before I start welding and the line would be a good 2-3 feet from my weld area.
    Is there anything else I should do before welding to make sure I dont go boom?
    Nov 2012
    Groves, Texas
    Re: Advice on a weld
    2 to 3 feet, I wouldn't worry about it. Just don't burn through the propane line with your arc and you'll be fine. Guys weld around pipes with explosive stuff in them all the time in refineries. Put your ground clamp as close to your weld as you can, within reason.
    Aug 2018
    Also I would use a welding blanket to drape on and around the propane line(s) to prevent any sparks. It doesn't hurt to be safe..
    Welds last longer than Love...
    Southern California
    I usually just purge them and plug any open ends (don't want any foreign material in there to clog things up) that may be exposed to welding debris (sparks, bbs, metal dust, etc). 2-3 inches shouldn't be a problem IMO
    Keep work/ground clamp near where you are welding.
    A welding blanket (fiberglass) is good extra safety as eventually propane lines/tanks get a nice coating of petroleum (flammable, possibly explosive - especially when heated) sludge inside, but to be honest I rarely use one welding around (empty! and open) propane lines unless I am so close I'm afraid I might arc up on the pipe itself.
    Remember propane is heavier than air so it will pool in low spots.
    Congrats on the new tool and hobby, welding opens up a whole new world and it's never been better to be a beginner. Machines are cheap/good and youtube is free school if you can wade through the bad info.
    Also, as a weldor you'll now have to stop and inspect EVERY weld you come across (talking trash is now mandatory), and many of those will give you nightmares as you realize much of the world is held together by some shoddy welds!
    Nov 2012
    Groves, Texas
    He said 2 to 3 feet.
    Why does he need to purge the propane line, he's not welding the bracket to it, is he? Me personally, I would not do anything at all with the propane, as long as it's not spewing gas in the weld area.
    Southern California
    He doesn't, really. But I would do it as it's quick/cheap insurance. I wouldn't purge and fill with inert gas or anything fancy, just clear the propane out to keep my inner hank hill happy. You're right though, it is pretty much overkill in this case.
    Southern California
    Kind of reminds me of unplugging advice. Everyone tells everyone else to unplug things when working on them or changing a blade/accessory, but how often do you REALLY do it? Lol I know i'm guilty as sin in that department!
    Aug 2019
    LOL: Thanks guys. I think I have a game plan now. Pretty much what my original intentions were. I just didn't want to be "That guy".
    Quote Originally Posted by esox07 View Post
    You don't want to get your 15 minute of fame on the TV ????
    May 2019
    Good luck esox07!
    Brethren, Mi
    More dangerous messing with it.
    Bemidji MN
    Quote Originally Posted by TimmyTIG View Post
    I'm with you. I wouldn't think twice about welding that far away from a metal line of propane.
    Plus, many people "purge" with air...an efficient way to make an explosion if ignited after.
    Airco 300 - Syncro 350
    Yeah, 2-3 feet should be more than enough... I mean it's not like you're welding and have open flames near a service like me...
    So...………….that was that ball of fire I saw on the NW horizon some time back Have yer eyebrows grown back yet???????????????? Oh, you pesky PNW guys
    Lol, yeh it was kinda hot!!! For a second... Glad I learned the drop and roll routine a long time ago has worked a few times ��
