oxy/acet cart
Results 1 to 25 of 29
Thread: oxy/acet cart
    oxy/acet cart
    im looking for a well designed oxy/acety cart. for the large bottles! this is too be used in heavy industrial areas so it needs to be well built, large tires are a must for rough areas. and a lifting eye so it can be thrown on a hook if need be. nothing fancy just able to hold the bottles, roll up the hoses on. most of the ones I see here on the net are pretty light weight with tiny tires. hoping someone on here might have a source or even there own design they might wanna share? if somehow the unit could even be towed behind the truck on the pintle hitch that would be beautiful.. as lifting these units into a truck is a chore.
    7*12 metal cutting bandsaw
    miller thunderbolt ac/dc
    tig torch
    victor oxy/ace cutting rig]
    hougen 904s mag drill...
    and of course the
    BFH!!!
    Re: oxy/acet cart
    This is the cart I have for bigger bottles but I would not consider it heavy enough duty for industrial use though.
    It can be adjusted from being vertical to 45 degrees.
    This is the homemade cart I made for midsize bottles. The tall wheels work well outside in the gravel maintenance yard.
    And my converted handtruck for single bottles.
    Apr 2008
    NW ON Canada
    Re: oxy/acet cart
    Any construction job I was on, we were never allowed to lift an oxy/fuel cart unless the cart was engineered to do so.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Re: oxy/acet cart
    We adapter a full size tank cart with car tires and hubs. Added a steel plate divider between tanks with lifting eye. Made up a bolt on / pin hitch to be pulled behind truck.
    I'm sure to could do a search too.
    Re: oxy/acet cart
    Have you checked Grainger? We used to get some really nice carts for the copper industry & I think it was from them, they had nice tires, about 24 inches in diameter and 3 inches wide on roller bearing wheels, they had a lifting eye attached to the bottom plate and could be had wit a tow hitch, albeit low speed for like a fork lift etc. the only thing I didn't like about them was the balance when moving them by hand.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    May 2017
    Re: oxy/acet cart
    Did you tow this down the road with bottles loaded on it? It sounds like OP wants to do this too. Is that legal?
    Re: oxy/acet cart
    I like this rig, Lis. Where did you find the wheels, or did you make them?
    Re: oxy/acet cart
    Quote Originally Posted by jeffrey.penfield View Post
    We towed on Jobsites and off road with tanks secured. This was not towed on city or town streets. You could also move by hand.
    It was basically a large bottle cart with the 24" steel wheels that we modified.
    Golf cart tires would work too.
    Re: oxy/acet cart
    yes this would never be towed outside the mill.. just for moving from one area of the mill to another. ive never seen one that can be towed like this. was just an idea which would make life much easier. one man could hook it on the truck and move it instead of 3 men to wrestle it into the back of a truck when no forklift is around...which is usually the case
    tig torch
    and of course the
    BFH!!!
    Re: oxy/acet cart
    snoepro
    your probably correct on that. back in the day we used to wrap a 3/8 choker around a bottle and let it fly but now days your not allowed to do anything sensible.. if I could find a good design and get it engineered that would be a way around that.. if I let the engineer design it. it would end up weighing 4 tons and take a team of horses to pull it....
    tig torch
    and of course the
    BFH!!!
    Re: oxy/acet cart
    Thanks, Kelvin. Those were wheels we had around on the farm. Not sure if they were off a wooden wheel barrow or...
    Here’s a pic of the backside
    Re: oxy/acet cart
    Lisa 2323 , I love that inline tank cart. I have a factory one and it's perfect as a space saver.
    My basic side to side one has the 24" diameter steel wheels. Now that's perfect for using on dirt or gravel.
    Re: oxy/acet cart
    Thanks, BD1.
    I obviously lost a bit of the space saving qualities with the slightly wider stance but I was concerned with stability.
    Re: oxy/acet cart
    This is almost exactly what we used, with the exception that ours had rubber pneumatic tires and didn't have the hose wrap.
    NRA LIFE MEMBER
    GOD BLESS AMERICA!
    RONALD REAGAN
    Re: oxy/acet cart
    heres the only 2 i could find on the net... someone on here must have built one..i cant be the only one to lazy to wrestle these into the pick up steady???
    tumbleweed-mfg.com/towable_torch_cart.html
    https://saftcart.com/554-30fw-t-2-554-30fw-t-le/
    tig torch
    and of course the
    BFH!!!
    Re: oxy/acet cart
    Quote Originally Posted by rambin View Post
    Yep, those are similar to what we made. Those are definitely nice carts.
    Apr 2008
    NW ON Canada
    Re: oxy/acet cart
    snoepro
    I have seen legit engineered bottle carts for lifting. You can get them.
    Jason
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Re: oxy/acet cart
    I really like the idea of being able to throw It on the pintle and tow it behind. I just hate the idea of buying one that I don't get to try first ive seen so many purchased and homemade carts over the years that just didn't balance worth &hit. big tires are the only way to go for sure. anyone have anymore then the 2 I found?
    tig torch
    and of course the
    BFH!!!
    Re: oxy/acet cart
    If you don't want to build from scratch buy a basic 24" steel wheel one. It's a not hard we made a bunch. Add axle and wheels, divider plate with eye, and hitch.
    Tack up and test for balance and positioning. Then weldout. We made a bunch and not difficult.
    There are hobby guys here that can do it.
    Re: oxy/acet cart
    This one looks liftable and towable.
    https://www.norco-inc.com/2381767/Pr..._Capacity,_840
    I agree with BD1. BUY a heavy duty one and mod it.
    Re: oxy/acet cart
    that would just be a lifting lug.. looks very similar to the 2nd website I added above. almost too similar down to the green paint! towing it from the lifting lug would put the bottles horizontal which I believe is thing we aren't allowed to do these days... not sure what angle there allowed to be at b4 its an "issue" though...
    tig torch
    and of course the
    BFH!!!
    Re: oxy/acet cart
    I would have three made by now. What's the holdup ? Are you really a wood butcher ??
    Re: oxy/acet cart
    The bottle angle would most likely be okay depending on the height of the towing vehicle’s hitch.
    new york city
    Re: oxy/acet cart
    i'm not sure i'd trust this hanging from a crane hook but was very easy to build from shop scrap. easy to push,it's got room for material and a fire extinguisher with a locking box in back.
    i.u.o.e. # 15
    queens, ny and sunny fla
  25. #25
    Re: oxy/acet cart
    cant lift it, cant pull it except on a concrete floor. maybe great in your garage, absolutely useless out in the field.
    tig torch
    and of course the
    BFH!!!
