Stacking Horzontal Welds
Results 1 to 2 of 2
    Hey...….I crapped up another thread with this. It should have been here. Apologies to Chickenfarmer. I see a teaching moment, and I get carried away..sorry man.
    Like builtup welds, horizontal welds need to overlap. You shouldn't see the upper toe of the preceding weld.
    I had to go back for these. I think they might have been some comparison welds using Excalibur, and Hobart 7018 from the ag store. Not sure.
Size:  103.2 KB Nothing special, just some padding (aka playing around)
    The base fillet was just a plain ol' fillet, and I guess I decided to play around, and run some welds up the wall. They're two distinct runs.
    What is important is the way the welds overlap the center on the previous weld below them. Keep an eye on the puddle, and let gravity carry it down over the crest of the bottom weld. Gently, without taking the arc from the face of the puddle, push filler back into the puddle to fill any undercut you get on the top toe. Gravity will try to drag the filler down from the edge of the top toe. This is easier with a wire welder (just a gentle tiny weave), but requires rod manipulation when running drippy 7018. Amperage should be close to a flat weld, or a few amps less when using larger rods. I'm pretty sure these were 3/32 welds (I run 3/32 at 85amps uphill/horizontal/flat/overhead......it's a very versatile rod when used out of position)
    So, again the same principle. You're creating a uniform weld without hills, and valley's. Each subsequent weld fills in the previous valley. Although I don't believe you see this very often, I believe it's considered a 2G out-of-position weld.
    Somethin' tells me that the first set of welds was Excalibur...…..it usually wins any comparisons. Wets out better, and allows for better control out of position. This is for me anyways.
    You get massive amounts of slag with Excalibur. That slag helps you differentiate bead profile against the dark slag background as you weld. Hard to explain, but you know it when you run it. The Hobart generates relatively little slag, and seems to freeze faster. Not saying it's a bad thing...…….it just doesn't mesh with the way I weld. I tend to weld slow, and like to be able to manipulate the puddle to some degree......I think the Excalibur has better surface tension in the puddle. Keeps it from sagging too much, while still remaining pretty fluid.
    Tried some of the ESAB Acclaim when I made the new bale spike thingy. I liked the fact that it's snappier than Excalibur, but the snappy arc also leads to more problems controlling undercut. It was a like/hate relationship I'm sure it's fine stuff, but I haven't run it enough to get used to it. Also didn't like the restrike...…….total PITA....worse than anything I've run. But it's good points outweigh the restrike difficulties....sorta. If you're running a smaller transformer machine like I do, you'll like the dig with the ESAB. It gives you a bit of extra oomph.
    May 2007
    Re: Stacking Horzontal Welds
    lincoln lh-70 would be better for what u do
