Making a repair on a piece of equipment with sensitive electronics.
Results 1 to 13 of 13
    Sep 2019
    When it comes to welding on equipment with a lot of intricate electronics what are some good and safe practices? Primarily for tig welding.
    Normally the equipment that I work on I am able to take the part off that needs to be repaired, but I now have a few parts that need some attention where taking them off for a repair will mean some major down time that can't be afforded. This machine has a lot of sensitive electronic components. What are some appropriate measures to take
    Re: Making a repair on a piece of equipment with sensitive electronics.
    While I haven't done tig work I have repaired a lot of electronics and their associated housings... And I've fried a few things due to little slip ups first rule: Keep your ground close to the work and make sure it is a good ground. Second rule: if your welder is line powered make sure any power lines to the device are decoupled. Most everything else is pretty much common sense.
    North Carolina / Maine
    Oxy-Acetylene is really nice for that--if you can stand the extra heat that the process gives off. But if you can TIG weld the thing in place, then O/A may very well work and there's no chance of electrical damage to the components.
    Outside of Raleigh, NC
    I always disconnect the equipment batteries so that the computers lack power, and ground on the same piece that I’m welding. It is very important to ground in a manner that the current does not go thru any axle bearings.
    I’ve also been known to disconnect and remove any electronic brain boxes.
    Miller Trailblazer Pro 350D
    Miller Suitcase MIG
    Miller Spectrum 2050
    Lincoln 210MP
    Heat sinks. And lift arc. Excellent grounding as close to weld as possible. With no electronics between you torch and ground.
    Yes, and I've also seen dump frames that had been welded on and left some nasty burns which turned into scoring on hydraulic cylinders!!! from welding current traveling through the cylinders rod and arcing between the gland and also the piston.... It's a quick way to kill bearings and cylinders... or any other moving part that gets welding current flowing through it
    When you weld, you introduce voltage into the metal...………...it's there, no matter where your welder work lead is...…...it's floating around.
    If it encounters an equipment ground, it will flow to "earth", and ya just ruined (maybe) and expensive controller. STRAY VOLTAGE.
    To guarantee safety, ya gotta completely isolate any electronics...…….just disconnecting the pos on the power supply doesn't cut it.
    Or worse, had a 10 ton RO boom truck and one of the idiots left his ground clamp on the truck and welded through the boom and cable. The extension cylinder rods took the worst of it. That was a spendy repair. Worked another job with a 55 ton Grove RT. The welders kept setting their stingers on the outriggers while the pipe (load) was grounded. They got so offended when I kept yelling at them and kicking the stingers in the dirt.
    Sep 2019
    With the piece of equipment I am working on I don't have the luxury of disconnecting every board. This particular machine is quite large, it has hundreds of circuit boards throughout itself, along with various PLC's and PC's. So disconnecting every board is not a option.....
    If I need to make a repair on a piece of this machine will I be OK with hooking the ground right next to my weld?
    My options for welders are Tig with HF, or a Lincoln Tombstone with stainless rod. I prefer tig, but if the HF will be the problem I can arc.
    You cannot turn off the HF? Is the tombstone DC? Can you tig with that?
    May 2007
    Quote Originally Posted by rolibr View Post
    look man, there aint noone here that can say yes. you know that. what you need to do , is go see one of them fortune tellers, that got a crystal ball. they can tell you more than we can
    Northern Cal., Shasta County
    Unless the part to be welded is on the outer most portion of this piece of equipment, just the routing of the cables could be problematic on something loaded up with PLC and/or PC controls. Look at the particles lined up along your welding leads laying on a concrete floor, then ask yourself if you want one or both leads laying on, across or between some digital components.
    If you have to do it, you have to do it. Separation distance to electric wires is your friend, and cross all wires at a 90 degree angle. Use scratch start tig rather than hi freq. Metal window screen around the weld area should help, tie to the equipment ground.
