AHP 201dx gas hose quick connect
Results 1 to 6 of 6
    Saskatoon, SK
    wrong section sorry - AHP 201dx gas hose quick connect
    Is the AHP gas hose a standard size? 3/16? I see there are a number threads pertaining to 201dx gas hose issues and I want to eliminate the cheesy quick connect gas fitting at the front of the machine and put on a 5/8-18 threaded inert gas fitting like the Miller DX et al use. I see it as a potential source for leaks and I am getting grey stainless welds and want to ensure it isn't a leak issue.. I realize there are a hundred other factors but want to address the leaks issue for certain. Working to get a portable flowmeter for the torch head as well.
    Sorry - this is in the wrong section, can't delete
    Re: wrong section sorry - AHP 201dx gas hose quick connect
    It’s a quick disconnect fitting, 9mm I think. Most new machines all use this connector. It’s called a QDGAP connector.
    I used the adaptor to fit a universal WP26 torch.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Quote Originally Posted by KevinF View Post
    Sent from my iPad using Tapatalk Pro
    Sep 2016
    Detroit, Michigan
    Quote Originally Posted by Andy Somogyi View Post
    It doesn't sound like he's looking for an adapter, but rather a way to get rid of the quick disconnect and replace it with a threaded fitting.
    http://mivise.com
    Millermatic 251
    Miller Dialarc 250
    Everlast PowerTig 210EXT
    The adaptor adapts the quick disconnect plug on the welder to a threaded fitting
    That won't get rid of the quick connect ? A adapter is not the answer when he wants to eliminate the quick connect altogether.
    He is looking for the panel mount standard bulkhead fitting for 5/8-18 thread gas line.
    Western AW15A is a 1/4" pipe to inert gas right hand 5/8-18 but what you really want is the same thing in a bulkhead style.
    Re: AHP 201dx gas hose quick connect
    Use this part along with a 1/4" pipe to barb fitting for the hose on the backside and use that fitting to retain the part in the front panel.
    https://www.amazon.com/Welding-Fitti...JD1SC2TG3X69HK
