Bridgeport Mill - tools - by owner - sale - craigslist
Bridgeport Mill. Works fine. DRO works.
I'd rather have that machine than the first Bridgeport in this thread. Probably has R-8 in the spindle? Looks like it has a face mill with inserts in it. I have a few pieces of tooling with straight shanks that fit in the collet, so you can use a face mill with a straight shank arbor to lock in the collet. Since you only need one collet to hold it, you can get an ER-40 collet chuck which will save you a bunch of dough on a number of tools. For this reason, ER-40 is probably the most common on mills, but for lathes 5C is king. It takes time to learn some of this stuff. This is not even to mention the Machinery's Handbook, and that print is so damn small, it's mostly formulas and calculations listed in charts.View attachment 1816080
Budget for riggers and professional machinery movers if you lack the experience or equipment to move it safely.
This isn’t something you buy pizzas and beer for your buddies to help you move.
This is my Taiwanese Bridgeport clone I moved myself. $1250cdn 15 years ago. ( no tooling)
That may be so, but that would imply buy blue or if you're a poor boy, buy red. Poorer, buy HTP...but I bought Primeweld and ESAB, both made in China, but both XLNT machines for my needs.I figure with a manual mill the same token is said with welders, buy once cry once and not need to upgrade in the future.
You should find another hobby, then. Just my opinion.I'm not interested in tramming the mill head every time I need to make room for a new bigger/smaller project.
I understand, just saying you might consider learning on a smaller mill that won't hog off your arm, before you know how to actually tram it. If you knew how to tram your mill, it should only take a minute or two, just like calibrating a vise, if you are afraid of taking your vise off because you'll have to re-calibrate it, then that's the time to consider learning how to dial it in faster, and not be afraid to do it.Yes they are cute and can get a lot of stuff done but if/when I want to hog off some material there is no replacement for some heavy duty " AMERICAN IRON "![]()
