So I got my 41 SA200 fired up.and running today. Machine probably hasn't ran a bead in 40 years. I have not had a chance to check the RPM yet, but I did run a few beads of 7018 1/8" with it today to see if it would weld and to see if the idler was working on it. I set the selector switch to 100 (it's lowest setting) and set the voltage down to its lowest setting and ran a short bead. It seemed a little cold for an 1/8" rod, so i turned up the rheostat to 20 and ran another bead with it. It seems to run it bit better but it acts like the arc force is turned all the way up, if the machine had an arc force setting. I am thinking I need to check the ocvs and RPM before anything. Does anyone know what the OCVS should be on this machine?
Thanks in advance.
Thanks in advance.
