OK, so last Chrismas the Lincoln Weldanpower 150 I restored (http://weldingweb.com/showthread.php?t=30753) was given to Brink M.E. (Mike) as a combination Graduation/Christmas present but it had to be given in a semi-completed state due to my inability to finish it in time.
As I stated to member DSW in member gordoflow's thread (http://weldingweb.com/showthread.php?t=43441), plans called for the conversion to electric start - following a comment by David R early on in the restore thread.
Post 'gift giving' discussions between Mike and I resulted in us deciding to add a 'hide away' towing tongue to the running gear in the event he wanted/needed to transport the unit any distance (off road of course).
I had the parts required for the electric start thanks to an 11hp vertical shaft B&S engine on one of two worn out Dixon ZTR mower 'donations' and we had already gathered up and set aside the critical pieces for the towing tongue so after changing out the single output AC only stator for the dual circuit unit and flywheel (original was missing a magnet) from the ZTR and installing the starter I moved forward with the upgrades yesterday.
A little repeat of a previous post, the original single output AC only stator on the right, replacement dual circuit AC/DC stator from the ZTR on the left.
Starter installed and AC 'field flashing' output routed thru welder housing grommet in place of original.
Flashing output connected to flashing diode.
1-1/2" angle for battery tray fitted and ready for welding in.
Battery in position. Still need to fabricate hold-down and mount START button once Mike and I get together on a position and wire it up.
Stand by for post #2 with the towing tongue . . .
