Brazing rod - hydraulic cylinder's rod, that is
17K views 14 replies 12 participants last post by  DougAustinTX
I did that repair once in the field with a cylinder for a D8. It was a crap shoot to save money & to finish the job due to time constraints on replacing the cylinder. Worse case scenario was rebuild or replace. Best case was back in service.
It is still in service as far as I know. My biggest fear was warping the cylinder. I had not questions as to getting it polished. I loved the feeling I could fix it. Great post.
Denrep, thanks for the explanation. I hadn't thought of all that. I did my repair with the cylinder still as one. The damage on my repair was near the end and when fully extended and with the use of thermal gel/paste I used what I thought would produce the least heat (thinking less warpage). I didn't want a weld pool to shrink and pull or not knowing the full make up of the steel cause laminar tearing that would cause some failure. I knew the bronze would be more forgiving than a weld bead.
Some knuckled operator wanted to weld a sight bar on the edge of the blade and drug some old cables across the cylinder. They arced all over the cylinder and buggered it up real nice like. I just happened to be scrounging for work when I came upon that repair. It got me some more work after that.
I would have liked to have thought of all that explanation when talking to the owner. he was skeptical but said hey if it works then I will pay you, if it doesn't I won't; either way, I think I will be either rebuilding or replacing this one. He didn't:)
