1 - 1 of 45 Posts
Fwiw, when I was in school for machine shop (a long time ago) we took the hss blank and only ground 1 side of it to the correct angle not both sides so it was at a point. By doing this you could utilize a factory edge and only have to worry about grinding one side correctly. The teacher also had us put layout fluid on the top and scribe out the angle for a guide when grinding. You then use the gauge when you stat to get close.
1 - 1 of 45 Posts
