Caring for aluminum.
2.7K views 9 replies 5 participants last post by  MoonRise
Also, be careful using an alkali-type cleaner (Greased Lightning, Simple Green, etc) as it will slowly etch and dissolve the aluminum. Wash, rinse well, and dry should usually be no problem. Leaving a chunk (or other piece) of aluminum soaking in an alkali will etch/frost/dissolve most aluminum after a while (depending on pH, temperature, dilution of the solution, etc, etc).
