1 - 1 of 23 Posts
If you puddle away from the joint your arc is too long. You got to get close. You must form your puddle in two seconds. Hit it hard! Once the puddles form, dab filler in the puddles. This part is tricky. You need enough heat in the puddles to melt filler, but it is very susceptible to keyholing. Once fused, move ahead. Heat until it is about to keyhole, dab.
1 - 1 of 23 Posts
