Hello,
I am currently in the process of restoring a Lincoln electric Ranger GTX 250. The welder generates power no issue and welds in AC mode only. after doing some investigation, and asking the previous owner, he stated the terminals for the choke coil had corroded off and instead of getting into repair, he decided to purchase a new welder. the machine has seen a lot of road salt & elements in its life. and as a result, the terminals for the choke coil inside the front cover area have corroded off. as a new coil is about $900
I would be curious to try and repair the coil before pulling the trigger on a new one. however I cannot seem to find where the terminals were previously affixed on the coil itself, and all results I can find online do not show where the actual terminals on the coil itself are/connect to
. if anyone has a similar machine with aforementioned coil and would be able to take a photo or show where the terminals attach, it would be greatly appreciated . photo attached of corroded terminals. machine code is 11400 if it helps.
thanks
thanks
