Customer had a basketball pole made from 6x8x3/8 rectangle tube. It had a 1/4” thick base on it that was failing, wanted a more substantial base. Cut off the old stuff to start fresh.
The new base will be 18”x21”x1/2” thick. Laid out the hole pattern and got out the trusty mag drill.
Prep work to get rid of the mill scale. It is clamped to a 1/2” piece of plywood, I made him a template for anchor install. He is going to pour a new pier, and will be using J-anchors when he pours the concrete.
