Problem with annular cutter & Milwaukee mag drill
31K views 43 replies 20 participants last post by  walker
I have the same setup. I use Milwaukees annular drills. Make sure the magnetic base is clean and flat. The thicker the base the better, although 5/8" should be enough. As said You can also turn the motor 180 degrees on the mount so there is not as much load. The less extension cords the better, make sure the ones you use are large. Now start the hole by lightly scratching until it marks the circle, now the hole will start helping to hold the drill as well. The Milwaukee cutters go on their own mount which lets oil wash through. You can also clamp the drill to the table if you just can't get it to hold still enough.
