Reading a bead.
6.3K views 15 replies 12 participants last post by  daddy
I've noticed that you experienced guys have the ability to "read" a weld bead, and determine what the problem is based on how it appears. This would be a very valuable skill to those just starting out. Does anyone know of any good instructional videos that cover this?
I suspect that this would be covered in any good welding course, but the next course in my area doesn't start for almost 3 months, and I'm too eager to wait that long!
If you are really that eager then start welding and breaking your work.
EXPERIENCE.
Weld something. Look at it. Break it. Repeat.
You will learn alot.
Mangler- As I read your other post, It seems that you don't have your machine yet. You are certainly a step ahead given the research that you have done and the questions that you are asking. However...there is no way to gain experience vicariously.Over the years I have aquired many different skill sets, in many different areas. There are lots of things that you can learn to do as a process. Step one, step two,etc,etc.Welding is different in that it is a dynamic process where a number of things happen at the same time to create a weld. I suspect this is why you are looking for more video to watch.I'm going to maintain that the video you watch while making your own arcs will be the most telling. I'm not trying to discourage you from seeking more info, just pointing out that until you spend some time with the hood down it is hard to even know what to ask.The books will show you pictures of what good welds look like, but the ability to "read a weld" like some of the pro's here can is only found after burning thousands of pounds of rods and wire .Good luck and stay motivated.:waving:
