Does anyone know how to hook up a remote to a sa200 without using a switch, 2 wire from the remote , the 2 that hook to the rheostat and then to the welder, I no it can be done by I am not sure what wire to hook it to in the welder, the welder was hooked up for a remote and they had the 110volt wires on the same recep in the welder, and somehow you can run a 110 recep to your remote box threw the remote cord and have a recep and your remote with you where you are welding. If anyone know how to do this could you put a rough drawing on here or tell me witch wire to hook up. Thanks Newt
