slamdvw, I agree about the great potential utility of windshield wiper motors and window winder motors. In fact, I was searching the All Electronics website for the listing of the automotive worm gearhead motors that I had picked up some time ago, "just in case," when I stumbled across the DCM-315 that I recommended above. However, I believe that the DCM-315 would be much more suitable than a randomly selected windshield wiper motor for a welding rotator primarily because of the fairly high basic no-load speed of typical WW motors.
I was looking at two new automotive WW or window motors from All Electronics in my motor drawer . Judging from the torn plastic bag with the ALL label, the two were sent under the same catalog number, DCM-61 (but I could be wrong that they both came under that number). The best and most suitable one runs at 32 RPM at low current (0.9 amp) at 12 volts, no load, and is extremely quiet and smooth. No mfgr. or part number printed on that one. This one could probably be throttled down to a useable speed for small workpieces on a directly mounted turntable.
The second draws 9 amps at 12 volts, no load, is fairly noisy, and runs at 160 RPM. This one is clearly not suitable for a directly driven work rotator due to speed. It gets very flaky if you reduce the voltage enough to get down to even a few RPM, which is still too fast. Lots of cogging, low torque, and stalls easily requiring higher voltage to get it started again.
Each of the automotive motors were about $15 to $17 a year ago (don't remember exactly), but I think the DCM-315 for $79 would be far more suitable for a direct drive turntable for workpieces up to, maybe, 100 pounds. Of course, the automotive motors would be fine if provided with further speed reduction, but then you are getting into a more complex project, having to provide a pulley and belt or gear arrangement and bearings to support the turntable.
I realize this is too late to be of any help to Jeff, but maybe some others out there are interested in building a cheap rotator.
awright
