Explanation of coarse current control for SA, and SAE type DC generator machines
This article describes how the two main coarse control systems used in DC generator machines function.
This article describes the detailed operation of the two most common coarse control systems used in Lincoln Electric's DC generator welders.
Both common types of DC generator machines control the coarse current setting by regulating the strength of the magnetic field in the series coil poles. The shunt coils, which are controlled by the fine control rheostat, produce a strong magnetic field in the generator. When the armature spins in this field, it produces weld output. The series coils oppose the magnetic field of the shunt coils. When the series coils become active, a magnetic field generated by the series coils will cause the weld output voltage to drop to a lower level. Because the series coils are connected in series with the weld load, they only become active when an arc is struck or a load is applied. This means that there is a higher voltage available when the machine is not welding, making for an easier arc strike. This voltage will immediately drop to a level more suitable for welding as soon as an arc is struck and current begins to flow in the series coils. This is how a dynamic drooping output curve, which is necessary for CC stick welding, is produced in this type of machine.
In the SA, Classic and Pipeliner type machines, a tap switch is used to control the magnetic field generated by the series coils. These tap settings, often called "Gears" by many pipeline welders, control the number of active turns in the series coils. The greater the number of active turns, the higher the magnetic field produced, causing lower weld output. The highest settings activate the fewest number of turns, and the lowest setting activates all of the turns in the series coil set.
The system used in SAE type machines, often called "Dual Continuous Control" uses series coils that have no taps. This system uses a reactor output control device which acts like a very high current rheostat, and is connected in parallel with the series coils. This reactor output control allows a portion of the current to bypass the series coils. In the Minimum output setting this reactor is open, causing all of the current to pass through the series coils. When placed in the maximum setting the majority of the weld current passes through the reactor, bypassing the series coils. This causes a weaker opposing magnetic field to be produced in the series coils. Settings between minimum and maximum are continuous. This continuous setting, in combination with the fine control, or job selector setting allows the operator to set the exact volt-amp output curve desired.
