I’ve been wanting to add some way to lift heavy things onto my 5x10 utility trailer. I already have a lifting arch with a winch on the tongue end and can pull things like logs up the trailer ramp, but wanted to be able to move my woodworking machines onto the trailer without straining myself and make it easy to move to our new location when the right property opens up.
This unit has a hand winch, but I’m gonna replace that with an electric winch powered by my deep cycle marine battery already installed on the trailer box welded on the tongue area. It rotates 360 degrees, and I will reinforce the area of the trailer frame with angle and plate, and use grade 8 bolts to secure it thru the 2x8 boards & 3/8” plate underneath on the frame, which I will likely beef up some with additional structural members.
Delivery is scheduled sometime between Jan 6 & 9. I hope frigid weather and snow do not hinder getting it installed on the trailer. I’m gonna have to figure out some sort of protective cover for the thing, as I don’t want it always exposed to the rain. I will certainly keep it sprayed with something like CorrosionX to keep it from rusting and operating smoothly. Probably will also install a jack on the frame side where it is installed to help take weight off the tongue when lifting heavy items.
