Never say never, but it makes sense.
360 degree orbital tube welding is done without wire on stuff less that 1/8", but thicker material that requires a joint, wire feed, and multiple passes is done "double-up", start at the bottom and go to the top, then go back to the bottom and do the other side.
If I recall correctly, I think the root pass on pipe is sometimes done downhill with stick (E6010).
I've seen machine cladding of SS downhill with pulsed MIG, but it had to travel around 60 ipm, while oscillating side to side, to stay ahead of the puddle.
