weld seam removal in square tubing
1 reading
25K views 17 replies 15 participants last post by  mike837go
I know this is an old thread but it is totally relevant.
What would happen if you welded some hard surface rod to the edge of the tube and then ground it to a sharp cutter edge ?
Could you use a threaded rod to pull it through?
