Welder questions
1 reading
901 views 32 replies 10 participants last post by  Xdavis
Hi, I'm buying my first welder for occasional use. I like the weldinger we2030p that packs pulse stick and ac/dc pulse tig inside a 22 lbs form factor. I know it takes only 230v that would require wiring from a dedicated two pole breaker if used in the US.
Since it's German, I have questions over the accessories compatibility. Eg the compatible tig torch specifies: 5-pin GX-16 control socket, suitable for welding inverters with 13 mm mandrel.
What are the names of these connections in the US and are they adaptable:
  1. Control switch: GX16 5-pin
  2. gas connection: quick coupling NW5
  3. welding socket:13mm welding coupling
#2 ·
For that price why don't you avoid the aggravation and buy a turnkey system. This unit looks 100% made in China. A good reference would be the PrimeWeld line of welders guaranteed to work seamlessly and has a solid warranty. Most of the PrimeWeld line is dual voltage as well, unless you are in Europe.
#3 ·
Not interested in a knockoff one. This can be purchased from their website..I know it could be made in China. Doesn't bother me.
All us welders with ac tig that I have viewed will be 40lbs +, including primeweld and yeswelder..
#12 ·
Only esab is in my price range.
Esab rogue 201i Pro Stick Welding weighs similar to weldinger, and has only dc.
#5 ·
The fact that i have never heard of the brand tells me that you will have a huge problem with after sale service and parts. If you are just getting started welding I definitely would recommend going with something that is much more common in the USA.
And as far as the weight issue…Always remember that just because someone figured out a way to make it weigh less dont mean they made it better in the process.
Another concern… you mentioned the 230v power which isn’t an issue but is it rated for 50 or 60 hertz?
  • Like
Reactions: NotaVegetarian
#30 ·
Here is one question we all have forgotten to ask. You say you’re a newby what is you skill level, if you don’t actually know how to weld start with a Mig, Hobart 210, Miller 211, these are good machines to start with. Just look at the door, material thickness, wire type, wire size, machine settings. And you are ready to go. Get a piece of angle iron and fill in the V making beads great for practice
