Results 1 to 17 of 17
Thread: 6 g stick cap
    Sep 2005
    St. John's, Newfoundland, Canada
    6 g stick cap
    So how do you get a nice smooth cap on the 6g im finding my stringers want to look stringy and not flat and tidy. Running a big lincoln, have had the arc force up, down, off.
    Have had amps from 95 to 130 Oh btw im running 1/8 7018s on the cap 6 inch pipe sch 80
    Thanks guys
    Journeyman / Red Seal Welder (What a useless test)
    Miller CST 280
    Miller XMT 350
    Miller 12vs Xtreme
    Evolution Evo 28 mag drill
    Evolution 380 Dry Cut saw
    Apr 2008
    NW ON Canada
    Re: 6 g stick cap
    I like to alow my pipe to cool before caping. If the pipe is too hot, caping will be a bit more dificult.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Sep 2010
    Re: 6 g stick cap
    Use 3/32. When you have that mastered, then learn 1/8.
    Re: 6 g stick cap
    things i try to produce when capping:
    get comfortable
    yes, let the work cool before capping and turn down the amps 5 to 10 amps.
    keep a tight arc.
    let your bead wash half way over the previous bead. You should be able to see the shadow of the line to wash over.
    hope this helps
    G
    Sep 2005
    Re: 6 g stick cap
    Maybe letting it cool will help. Just a straight run, no manipulation at all or ? I can run a better cap at home, its kind of funny. Must be because im not confined to a booth thats cramped.
    Thanks guys
    Miller CST 280
    Miller XMT 350
    Miller 12vs Xtreme
    Smalbany NY
    Re: 6 g stick cap
    I prefer a hot pipe for cap, runs smooth and fast. I look like Barry Bonds while pipe welding, my left arm is wrapped in armor so I can lean right on pipe and be stable, overhead, up or flat.
    Lincoln Power MIG 210 MP ( boat anchor )
    Lincoln Weld-Pac 100 HD
    Hobart IronMan 230
    Cutmaster 42
    Jackson NexGen
    Sumner Ultra Clamps
    DWM120
    Apr 2012
    Re: 6 g stick cap
    Just take a good water break and let the coupon cool a little bit. Not completely. I do tight circles. Dont go crazy with your rod movement.
    Mar 2008
    Re: 6 g stick cap
    even on 6" i'd put 2 stringers, looks better to me than a mac daddy weave.
    dave
    Mar 2012
    Soon to be paradise
    Re: 6 g stick cap
    If you put a small z weave with your stringers it will help flatten it out but will keep the stinger look your looking for. Also when you are weaving your rod keep your side to side motions parallel with the ground.
    1973 Lincoln SA 200, Already replaced shunt coils, Idle board (SOLD)
    1984 Miller Dialarc 250HF, Miller water cooler, 250 AMP water cooled torch, you know the worx.
    Apr 2008
    Charlotte NC
    Re: 6 g stick cap
    Correct rod angle is critical to a smooth, flat cap.
    Miller TrailBlazer 251
    Miller HF-250-1
    Miller MaxStar 150 STL
    HyperTherm PowerMax 380 plasma
    Lincoln PowerMig 180
    Millermatic 252
    Miller Diversion 180
    Sep 2005
    Re: 6 g stick cap
    Got the cap almost down my biggest problem is too much fill and being over on my cap. We are running 3/32 7018 root and hot pass with 2 stringers on top of that and then the cap. The 2 stringers and cap are done with 1/8 7018, a lot of the guys are knocking down their passes in between so they dont go over on their cap. I may have to do the same to get the results I need.
    Miller CST 280
    Miller XMT 350
    Miller 12vs Xtreme
    May 2012
    Re: 6 g stick cap
    Do you have to do the 1/8 7018? I just finished school and we did 3/32 all the way after our root and hot pass. we also used schedule 80, and to me 1/8 for the cap seems excessive the 3/32 were plenty for us. I used a clockwise slow circular motions when going up the left with the edge of the puddle barely touching the edge of the bevel and and a counterclockwise motion when going up the right side. Then when doing my second bead did the same thing just watching the bottom of my puddle making sure I had the correct overlap and going the same speed. I found by doing the clockwise going up the left and counter up the right I didnt have to watch the top of the puddle and never got undercut. Im not pro just my .02 cents
    Sep 2005
    Re: 6 g stick cap
    nah has to be 1/8 aparently no grinding on the test either only on start stops so im going to have to get it right.
    Miller CST 280
    Miller XMT 350
    Miller 12vs Xtreme
    Oct 2011
    alabama
    Re: 6 g stick cap
    Quote Originally Posted by Newfie_1986 View Post
    Reduce the amount of fill you put into the pipe, that'll allow you to run the 1/8ths without all of the overfill on your cap.Alot of the seasoned guys don't let their pipe to cool down before the cap but in learning the trade you will need to do this for the pipe to "take" the cap better.JMO
    Magicial Magician Of Molten Metal
    2006 Chevy Dually Welding Truck
    1975 SA-200 Lincoln Red Seal
    Miller AEAD 200-LE
    Lincoln 225 AC/DC tombstone
    Victor Contractors Flaming Tomahawk
    Profax Tig Rig
    More pipe fitting tools to mention
    Metabo's
    Sep 2005
    Re: 6 g stick cap
    Reducing the amount of fill is the only way, but I cannot go down in rod size, the only answer is to run hotter and move fast on the fill passes to leave enough room for the cap. How much bevel do you all usually leave for the cap to fill in ?
    Miller CST 280
    Miller XMT 350
    Miller 12vs Xtreme
    Feb 2010
    Ocean Springs, MS
    Re: 6 g stick cap
    Quote Originally Posted by atc250r View Post
    I agree with this also run the 3/32 fast as you can without getting undercut and the bead will be nice and small and flat :]
    Sep 2005
    Re: 6 g stick cap
    lol guys I cannot take the test with 3/32, great idea but they will fail me for it. 1/8 is it
    Miller CST 280
    Miller XMT 350
    Miller 12vs Xtreme
Page generated in 1,713,283,520.15623 seconds with 17 queries
