Results 1 to 5 of 5
Thread: cst 280/ wire feeder?
    Dec 2011
    Tampa FL
    Can I run a 12VS feeder with a CST 280?
    Dec 2011
    Tampa FL
    Re: cst 280/ wire feeder?
    bump.
    Feb 2008
    North of Philly
    Yes, sort of... You can run a VS feeder from any CC power source with enough amps to run large FC wire in spray mode. Small solid wire in short arc ( which is what most people think of when they think of mig) will not run well at all. The feeder simply can not make the wire speed adjustments fast enough to mimic CV running that type of wire. Large wire FC is a hot process and will lay down a ton of material in a hurry, but vertical and overhead will be a PITA to run. It's probably not what you want to run. If you have heavy steel that needs big welds, fine, but if you need to do less than 3/8" it's probably not worth the hassle.
    Ronald Reagan
    Dec 2011
    Tampa FL
    Thanks DSW thats what I thought but wasn't sure. Looks like I might need to start looking for a mig machine. Again Thank You
    Apr 2011
    VA
    If you already have the 12VS you don't necessarily need a dedicated MIG machine, just a CV power source. An XMT would work, among others.
Page generated in 1,606,499,192.66447 seconds with 11 queries
