Results 1 to 23 of 23
Thread: Can I plug a 120v 20 amp arc welder into 250v 20 socket?
    Jul 2012
    I am new to arc welding. I have a welder with a 120v 20 amp plug, but my house only has a 250v 20amp socket. Can I run my welder off that socket as is? The arc welder's plug fits that wall socket, I tried it, but it I DID NOT turn the welder on. Will something bad happen if I hit the switch?
    Any advice is useful!
    Feb 2012
    Huntsville, AL
    Re: Can I plug a 120v 20 amp arc welder into 250v 20 socket?
    If your unit IS 120v, DO NOT plug it in to a 240v outlet. You said the plug end of your unit would fit the 240v outlet... Are you sure that your unit is not 240v?
    Journeyman Electrician
    (2) 135AC/ 105DC Amp Arc Welders
    (1) 165A Inverter Arc/TIG Welder with Digital Readout
    (1) WP17V Torch for Scratch/Start TIG welding
    (1) AR300 Cylinder
    Mar 2012
    This sounds like a case of either a POS chinese welder that's got the operating voltage mislabeled, or a POS chinese welder that's got the wrong plug stuck on it. Any chance you can confirm either way? Perhaps provide a picture of the unit, and a closeup of both the plug and the aforementioned 240v outlet?
    If it's a 240v welder, you're fine.
    If it's truly a 120v welder, sure you still can... if you like fire and death.
    Technically... with a plain old transformer based arc welder, it would work. A transformer will do its thing regardless of the voltage. That said, by doubling the primary voltage, you'll be doubling your secondary voltage, which will make your stinger live with more than enough voltage to sizzle you, and you'd probably burn down your house, or garage, not to mention yourself.
    If it's an inverter based welder, it'll fry.
    You didn't build that.
    '85 Miller AEAD-200LE
    Delaware
    If you like the fireworks on July 4th then turn it on
    Anchorage Alaska
    Make sure you get the video going when you flip the switch. you could make it to the next ...
    http://weldingweb.com/vbb/showthread.php?t=145531
    Feb 2008
    Indiana
    Quote Originally Posted by Saberstorm View Post
    You house only has a 250v 20amp socket?? With no location we have no idea what part of the world you are in.
    Tim Beeker.
    Sparks, NV
    Not sure what country you are in, in the usa each leg is 110vac so only one leg and neutral it will technically work but not safe with no ground.
    I know in uk each leg is 240 so it will instantly fry..
    Feb 2008
    Indiana
    A standard 3 wire 220v plug is 2 legs 120v each and a ground. No neutral.
    Tim Beeker.
    To answer your question, we need to know the make and model of the welder.
    A picture of the data plate might help. If you are in USA. A 115 volt plug should not go in a 240 volt receptacle unless it has been bent. A 20 amp flat blade plug has one blade turned 90 degrees. The 115 volt and 240 volt versions are mirror opposites so you can't plug them in wrong. Read the owners manual. welders come in single voltage, adjustable voltage, auto link and auto line. Connecting a low voltage welder to a higher voltage will most likely cause it to burn up.
    Feb 2008
    Pretty sure what he is talking about is the volt (250) and amp(20) rating of the device itself.Just like a 220v nema 50 receptacle is rated at 600 volts capacity.I think
    Jan 2012
    Outside of Austin TX
    You never know it could be a 240 volt 20 amp socket. You use to have them in houses all the time when all you had was window unit a/c's.
    Dec 2007
    Los Angeles
    he must have turned it on- 1 post and he hasn't returned
    Ed Conley
    MM252
    MM211 (Sold)
    Passport Plus & Spool gun
    Klutch 120v Plasma cutter
    SO 2020 bender
    Beer in the fridge
    Jun 2008
    Each leg is 120V on a 240V circuit, in the UK & the rest of the 50 hertz world it is 240V line to neutral, but it has been "harmonized" to 230V.
    Apr 2010
    Saberstrom
    You can; but you may not.
    Consult a local electrical professional.
    This is a really simple question, but
    all of the parameters must be viewed
    in person, by said e/p.
    Opus
    May 2012
    Western Pennsylvania
    Can you say " I LIKE FIREWORKS AND LOTS OF SMOKE REAL FAST???"
    Lets just say the water melon in the video is your welder!
    [ame]http://www.youtube.com/watch?v=gj1pkyCL75E[/ame]
    Jan 2008
    Richmond, Virginia
    You suppose they could sell that capacitor bank to Gallagher?
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Sep 2011
    Woodsfield, Ohio
    Old thread but I think a number of folks missed the solution for something like this.
    I suspect he actually has a 110VAC receptacle of some breed that is why the plug fits. Maybe he is seeing 250V rating markings on it, getting confused.
    Simple solution would be just read the voltage with a meter. If only 110V out then good to go. Plus the power wire coming in should give you a clue.
    When in doubt, never believe what you think the power plug is telling you, always believe the meter. If you don't really understand that sparky stuff, get somebody that does.
    Feb 2008
    NH no mo - MA now.
    Quote Originally Posted by Fat Bastard View Post
    Waaa! The video is no longer available because theYouTube account has been terminated!
    - Mondo
    Member, AWS
    Lincoln ProMIG 140
    Lincoln AC Tombstone
    Craftsman Lathe 12 x 24 c1935
    Atlas MFC Horizontal Mill
    I'll just keep on keepin' on.
    Northern Cal., Shasta County
    Quote Originally Posted by Mondo View Post
    - Mondo
    Removed out of respect for the deceased maybe.
    Jun 2019
    I'm ashamed to say - I did this. However, I knew and understood the difference between 120 and 240 voltages, and I just did not read the label on my machine. I incorrectly remembered that it came with an adapter plug from 240 on the wall to the 120 machine plug (which was not the case.) Figuring that I needed the extra voltage to get the higher amps out of the machine, I did the handy thing and built a plug. I turned the machine on, plugged the machine into the adapter and then the adapter into my 240 outlet. The machine ran for about a minute, I did not get a shock when I touched it to test, then it died. For good. No fireworks, smoke and sparks, or fried fat guy. Just a poor little welder that is now scrap.
    Jan 2016
    northeast USA
    read the instructions...................................... ....or is that too obvious ????
    Jan 2016
    northeast USA
    Quote Originally Posted by beefire9 View Post
    once again why read the instructions that come with tools, just use them to line the bird cage.........darwin at work...
    Jul 2011
    Bossier Parish La.
    You're probably right, as he still hasn't returned since that fateful day back in 2012 when he first posted this question and did not wait for any answers on it. Went and turned himself in to a Crispy Critter.
Page generated in 1,713,270,584.80066 seconds with 19 queries
