Re: NEW ForceCut 42i Blow Back Pilot Arc Plasma Cutter with PFC (110v/220v)
[ame]http://www.youtube.com/watch?v=YPRUNRruRz0[/ame]
I got the Forcecut going! At first I had some problems getting air to the machine, but that was because of the air fitting on the back of it. Longevity's customer support talked me through a simple solution (hose-clamping an air line directly to the fitting, instead of using a coupler), and assured me that the problem fitting I delt with, will be replaced with a standard quick connect fitting. So, it should NOT be a problem if you get one of these machines from them.
Anyway...
This thing cuts wonderfully! In part 1 of this video series, I did some severance cutting with it, tested out how thick it will actually cut. It has a very narrow and highly controllable cut/plasma arc, and really does seem like a nice little machine.
Part two coming soon, what do y'all think of it so far? Anything you'd like to see me do in parts 2 and 3?
[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
