Results 1 to 4 of 4
Thread: Weldanpower alternator
    Sep 2012
    Kansas City
    I had a question about my Alternator. As I was taking my engine apart in class I found that there was only a half ring style type I couldn't find a part number on it and in the parts list it looks like its only AC or DC. I really want to have both does this mean I need to order the dual circuit type? The info I have on it is as follows.
    Weldanpower AC/DC-210-6
    Auxiliary power: 6Kw,115/230/1/60
    Model: 326437
    Type: 0375-01
    Code: 8102021
    May 2008
    Orange, TX
    Re: Weldanpower alternator
    The one you're looking at is an unregulated AC output which provides the initial flashing current for the welder/power rotor. The flashing diode in the circuit rectifies output to DC.
    What is your reason for using a dual output? I used one for battery charging in converting a manual start Weldanpower 150 to electric start.
    Name:  Electric Start Conversion 001.jpg
    Name:  Electric Start Conversion 007.jpg
    Name:  Electric Start Conversion 008.jpg
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    Sep 2012
    Kansas City
    Well right now I have-had a breaker point ignition system. The bushing was so hard to get off we ended up drilling it out and, very carefully breaking it off from the inside. I'm hoping to bypass the breaker points system using a solid-state ignition retrofit kit. So, I guess I'm not going to need the dual output.
    And thank again Duane! Your the man!
    Sep 2012
    Kansas City
    I was also wondering if anyone knew where to get the repair manual for this model. I got the operating manual and parts list. But I'm taking just about every bit of this apart. I just emailed Lincoln so I'll see what they send me.
Page generated in 1,606,458,117.78069 seconds with 12 queries
