Results 1 to 19 of 19
Thread: Who here knows their old Ford trucks?
    Oct 2010
    Indianapolis Indiana
    Have a 1975 f350 dually.
    360ci v8 with a 4 speed manual.
    2Wd with a Dana 70hd rear.
    Old gal wont shift into 3rd.
    No grinding or odd sounds.
    Just wont shift into 3rd even with the engine off.
    A.) How can i find out what trans this is?
    B.) Think its an adjustment issue or something broke?
    Miller Dynasty 200DX
    Miller Spectrum 250D
    Miller Millermatic 200
    Bunch of old blue dinosaurs....
    Sep 2006
    Marlborough, The Peoples Republik of MA
    Re: Who here knows their old Ford trucks?
    Pull the cover off the tranny and look for a broken shift fork or guide rod. If something in the tranny is bad a NP435 is an easy rebuild.
    Sep 2006
    A New Process 435 has an aluminum cover and the shifter pops out with a quarter turn of the retainer, a Borg Warner T18 is all cast iron and the shifter retainer needs to be unscrewed.
    Aug 2008
    If it's a New Process good luck getting anything but gaskets and other minor parts for it. Haven't been able to get parts for these in well over 10-15yrs. MIght get junkyard stuff, or custom machined stuff, but that's it. There's so called "rebuild " kits out there but the stuff is minimal (gaskets, bearings, synchros). I retired my old 78 Powerwagon for this very reason, I can't justify pulling it hard when I can't get drivetrain parts should something break.
    http://www.farmersamm.com/
    Mar 2012
    Montana
    Feb 2012
    I dont know for sure but it sounds like the 3rd gear synchro went out. I had the same problem in a 73 F150 4wd that had a funky xnsfr case that had no neutral. When I towed it, it burned out the synchro due to no splash lubrication when being towed and the engine off.
    What I mean is, when you tow it, the output shaft is spinning and lubed but without the engine turning, no front shaft lube.
    Feb 2012
    BTW, I have factory manuals for 1973 that I think is the same as '75. If your interested , I can trade for consumables or gloves whatever.
    Oct 2012
    If I remember correctly 3rd gear was located on the output shaft by a two piece retaining ring. These rings had a habit of breaking. this allows the gear to move out of position and not engage. This ring can be replaced without removing and dis assembling the trans. It is not easy job but it can be done. Remove the lid from the trans and check if 3rd gear moves on the output shaft. If you look closely you will see where the ring fits into the recess in the gear. As I said it can be replaced without trans removal.
    Feb 2012
    The nomenclature (tag on door) codes for FORD F-B-P 100-600 series 4 speeds are as follows:
    A New Process 435 (most common around here)
    F Warner T-18
    P Warner T-19
    May 2008
    Orange, TX
    1975? I thought you said "old".
    MM200 w/Spoolmatic 1
    Syncrowave 180SD
    Bobcat 225G Plus - LP/NG
    MUTT Suitcase Wirefeeder
    WC-1S/Spoolmatic 1
    HF-251D-1
    PakMaster 100XL
    Star Jet 21-110
    Save Second Base!
    CT
    not sure but I think the 2 whl drives use the same tranny with and adapter, find a donor and get a whole tranny to swap in, done.
    "Si Vis Pacem Para Bellum"
    Lincoln Idealarc 250 AC/DC
    Millermatic 251 Syncrowave 300 30A spoolgun
    Lincoln MP210
    Hypertherm 45
    (2) LN 25
    (2) Lincoln Weldanpower 225 CV
    (4) SA200 1 short hood SA250 SAM 400
    Feb 2010
    Northern MN
    Any of the old 4spd's they put in those trucks are pretty easy to tear down and rebuilt. The bigger challenge is actually picking the damn things up, their cast iron and heavy (the NP435 is really heavy, the others arent that bad). Parts are available as are reman units if you look around a bit. They are a very popular swaps for Jeeps and rock crawlers due to their being both very very strong and having a really low first gear.
    Aug 2009
    Dec 2011
    Milford NY
    I have a np 4 speed sitting in my barn. I'm in Ny and you in minnisota, could probably
    Ship it but once you figure that in, it's probably not worth it.
    Miller bobcat 225g - spoolmatic 1
    Mm250 - 30a spool
    Miller spectrum 375
    Thermal arc 95
    Everlast Ex 250
    As the boiler turns, these are the days of our lives
    Sep 2011
    Jasper TX
    Sorry, mines a little older, 61', work in progress...
    Jul 2020
    ford truck shop manual pdf download.
    Sep 2005
    Cave Creek AZ
    Hopefully he figured it out in the last 8 years.
    You first post and you drag up an ancient thread.
    Could be a pdf with tracker.... or more
    Apr 2016
    Old ford old thread.. I thought it was going to be an old ford, like a marmon.... '75.. haha. Guess problem solved by now though.
Page generated in 1,603,982,226.99089 seconds with 12 queries
