Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: 140 Amp Machine on the Way!
    Jan 2008
    N. California
    Re: 140 Amp Machine on the Way!
    Quote Originally Posted by longevity-inc.com View Post
    gaustin,
    I am checking to see if a 50 amp plug is too much for the unit. I believe it doesn't draw that much power.
    Hope to have a reply soon.
    Simon
    So lemme get this straight, I'm having a hard time here ....... you are saying,,,,,,, if you plug the machine into a receptacle with TOO MUCH available amperage, it will not work properly??????????
    I think you yourself should go attend a basic sophomore high-school electrical course ........
    Jul 2004
    Iuka Mississippi
    Quote Originally Posted by Matthew View Post
    cool... post pics of your first welds with it
    Here is what I could get out of it earlier this AM. Still cutting out randomly.
    http://weldingdata.com/WelderReviews...s/P1050646.JPG
    http://weldingdata.com/WelderReviews...s/P1050647.JPG
    I don't have any 1/8" 7018 right now but hope to get some this week and see what they can do.
    I checked all of my connections again and no hot spots that would be evidence of a bad connection.
    I don't have an AC Ammeter so I can't see what it is drawing.
    Have a nice day
    Gerald
    Jan 2008
    Hayward, CA
    Sorry I wasnt thinking and posted that late at night...
    LONGEVITY
    Phone: 877-566-4462
    Jan 2008
    Hayward, CA
    Quote Originally Posted by gaustin View Post
    Have a nice day
    Gerald
    Gerald,
    I will contact you on Monday with some of the welding problems you are having. If we cannot find a solution to check over the phone, I will replace it and cover all shipping charges.
    I am sorry you are experiencing problems.
    PS: The video is a little dark, but the pictures look nice.
    LONGEVITY
    Phone: 877-566-4462
  5. #30
    Jul 2004
    Iuka Mississippi
    I have been able to run a few more beads with the machine. I welded a handrail for a friend that recently had knee surgery and the welder worked well but I haven't had much time to really test the welder yet.*
    During testing using some E6011 I had problems with the machine cutting out. I beleive I found the cause in the ground clamp. The picture below is what I think was causing the problem. I have since replaced the ground with one from a HF machine but have yet to retest using 6011.
    http://weldingdata.com/WelderReviews...roundclamp.JPG
    I did get a chance to run a few 1/8" E7018 prior to going on vacation last week. I just ran a few beads inside a piece of 2-1/2" x 2-1/2" x 1/4" Angle. The welder did not cut out at all and the heat seemed consistent throughout. A true test will be 6 minutes straight of welding and then 4 minutes off.
    Below is a picture of a few beads run verical up. These were made to show what the welder would do. Not what the WELDOR can do. I have made prettier welds in harder places and uglier welds in easier places.
    http://weldingdata.com/WelderReviews...4Angle7018.jpg
    Again, anyone with a Red, Blue or Yellow inverter that weighs within 10 LBS of this one is welcome to do some testing with me. Flat, bead on plate 1st to check out the duty cycles, then a few butt welds in plate and pipe.*
    Last edited by gaustin; 07-27-2008 at 05:09 PM. Reason: Tried to show pictures but cant figure it out!
  6. #31
    Jul 2004
    Iuka Mississippi
    Below is a slideshow showing a multipass fillet weld on 1/2" plate made with 1/8" E7018.
    This was all done with less than 20 seconds between each electrode. The machine did not seem to fluctuate any during the weld. The 6011 pass made on the 1st bead welded nicely and the arc went out one time at the top. This could have been the result of me not paying attention to the arc length. You can view the video better if you scroll down and on the right side of the screen select the "View Full Screen Icon" nor just go to the actual page at http://weldingdata.com/WelderReviews...illetweld.html
    Code:
    Gerald
    Last edited by gaustin; 07-28-2008 at 08:35 AM. Reason: Added comment about view foll screen and added link to page.
  7. #32
    Jul 2004
    Iuka Mississippi
    I made a few updates to the review ppage for the MMA 140 welder. http://weldingdata.com/WelderReviews...vityMMA140.htm
    The machine I have seems to meet the duty cycle listed on the machine. Without an ammeter its hard to be certain. I did post some pics on another section of the forum bit they are one the page . The main point of the test is the fact that the welder was able to weld with the power turned all the way up for a period of time that exceeded the duty cycle rating.
    I also dropped it a couple of time and it continued to weld. Here is the video of the actual dropping .http://weldingdata.com/WelderReviews...ng140drop.html
  8. #33
    Jul 2004
    Iuka Mississippi
    I was able to setup a tig rig on the machine at lunch today and weld a few beads. Also updated the review page. http://weldingdata.com/WelderReviews...vityMMA140.htm
    Here are some pics.
  9. #34
    Jan 2008
    Hayward, CA
    Gaustin,
    Thanks for showing us your work and informing those people on this site who are interested in our equipment.
    You have done a fair and great job with your reviews both on here and on your website.
    Simon
    LONGEVITY
    Phone: 877-566-4462
  10. #35
    Jul 2004
    Iuka Mississippi
    Here is a bead with some stainless.
    http://weldingdata.com/WelderReviews...ity/ssweld.JPG
Page generated in 1,713,294,626.54206 seconds with 18 queries
