Results 1 to 6 of 6
Thread: AC not working on PowerMaster 205
    So my second PowerMaster 205 decided to fail today. My original PowerMaster 205 was purchased in Jan 2010, and failed in November 2011. They sent me another new (albeit older looking version) PowerMaster 205 and now I'm having an issue again about a year and a half later. Today I switched it to AC and the welder decided to give me DC+ at the torch, destroying the tungsten in the process. DC still works ok. No combination of switches seems to get it to run AC anymore.
    I opened her up and checked all the connections. I reseated all the connections, checked the ohms on all the pots, checked all the wiring I could get to, and basically have concluded that beyond this, I'm out of my comfort zone fixing this thing. Does anyone else have any ideas? Is there any set of LEDs on the top board that I should be looking at to diagnose the problem? Switching between AC and DC doesn't turn on any different combination of LEDs.
    All the stuff on the board all the AC stuff goes to seems to be in order.
    HELLLLLP!!!
    Nov 2008
    Re: AC not working on PowerMaster 205
    If I remember right, there are a couple of connectors right behind the LED display on the top board. Double check those. Likely one is loose. It's a tight fit in there, so it can be overlooked.
    Esab Migmaster 250
    Lincoln SA 200
    Lincoln Ranger 8
    Smith Oxy Fuel setup
    Everlast PowerPlasma 80
    Everlast Power iMIG 160
    Everlast Power iMIG 205
    Everlast Power iMIG 140E
    Everlast PowerARC 300
    Everlast PowerARC 140ST
    Everlast PowerTIG 255EXT
    I reseated and checked every single connector and wire on the top board.
    Jan 2008
    Cal-i-forn-i-a like Swarzenegger
    Quote Originally Posted by killernoodle View Post
    killernoodle
    please PM me all your info and Ray from tech support will call you in the morning
    Oleg
    So your tech support guy called me up and tried to convince me that the reason AC wasn't working was because he thought I had too much gas flow. That is indeed not the case (as I tried to explain to him). I certainly get an arc, just no AC wave.
    What is the next course of action here?
    Feb 2013
    that was also the first thing he told me about my welder not starting a AC weld with the pedal. I was like u gotta be kidding me
Page generated in 1,607,022,706.92614 seconds with 11 queries
