Results 1 to 11 of 11
Thread: Looking for a quality TIG welder.
    Apr 2013
    San Diego, CA
    I'm local to the San Diego area and I was curious if anybody is selling a good TIG welder that would be suitable for welding aluminum. I only (currently) have access to a 110V outlet in my garage (at some point, I may have an electrician out to change that), so if anybody has a machine that can handle dual input that would be great. Apologies in advance if I'm asking in the wrong place.
    Feb 2008
    North of Philly
    Re: Looking for a quality TIG welder.
    There are machines out there that will do AC tig on 110v power, but they have some issues you need to be aware of. They usually are very limited in output on 110v power. Chances are at best you'll be able to weld maybe 16 ga with standard 20 amp dedicated circuit without tripping the breaker. Specs on a machine like a Dynasty 200 show it will max out at 150 amps on 110v power, enough to do 1/8", but to do so you need a dedicated 30 amp 115v line. If you have to run the line anyways, run 230v power which would let you do 3/16" alum with that machine.
    2nd issue is most of these machines are not cheap. Millers Diversion will run on 110v power and isn't too bad price wise, but out put isn't great, especially on 110v power, and you give up all the advanced features. Dynasty's will set you back almost $4K new. Used ones show up from time to time, but still command premium prices. Those you find dirt cheap, usually are either scams, or dead machines guys are trying to dump on some unsuspecting customer. Dead machines usually end up costing you more to repair than they are worth. Make sure you test and confirm a "deal" works and you can physically lay your hands on the unit before you plunk down money.
    Ronald Reagan
    Feb 2009
    Chicago
    What i have used and seem to work pretty well on 110v.
    Miller diversion 180 (the 165 is 220v only)
    Eastwood tig
    longevity 200sx
    htp 221 dv
    There are machines out there, just depends on your budget.
    Hypertherm Powermax45
    2015 AHP Tig
    Razorweld 195 Mig
    Razorweld 200ac/dc Tig
    ViperMig 180
    Razorweld, Vipercut/Vipermig, SSC Foot Pedal & MK Products & Atlas Positioner Dealer
    May 2010
    Sparks, NV
    If you have a washer and dryer in the house or garage you should have at least a 30 amp 220vac hook up. Then you just got to make an extension cord. DSW hit the key issue, that is welding thickness on 110vac. what thickness are you trying to weld?
    Apr 2013
    San Diego, CA
    It's a gas dryer, I'm pretty sure it's only 110v. To be fair I've never actually dragged it out and seen the plug myself.
    I had looked at the Longevity and the ThermalArc. Both seem to be "budget" welders, which claim to do TIG on 110V. I may just bite the bullet and see what an electrician costs. Though my braker box is almost maxed out. Old house (1926), with knob and tube wiring.
    Houston, TX
    Quote Originally Posted by porosity View Post
    The T/A and Longevity welders will fdo a good job on 110, as will several other dual voltage machines. I have the Longevity 160SX, and it does both Tig and Stick well.
    Apr 2013
    San Diego, CA
    Quote Originally Posted by cope View Post
    I've heard people tell me that they're **** and it's better to find a good used Lincoln or Miller machine. Which is what lead me here.
    Mar 2006
    Yuma, Arizona
    they were right about the lincoln. I was kind of excited to see your post until I saw your voltage limitations.
    I am kind of in a tight spot and considering selling my Precision Tig 275 Ready-Pak with Advance Panel. I would deliver it to SD
    Lincoln TIG 300-300
    Lincoln Hobby-Weld 110v Thanks JLAMES
    Apr 2010
    You won that real mean little lincoln stick machine that would be more along what his capabilities currently are...Electrically speaking
    What would SATAN do ??
    Miller Trailblazer 302 AirPak
    Miller Digital Elite
    Optrel Welding Hat
    Arcair K4000
    Suitcase 12RC / 12 VS
    Hypertherm PM-45
    Rage 3 saw
    Rusty old Truck
    Apr 2013
    San Diego, CA
    Quote Originally Posted by Joker11 View Post
    I'll look at my breaker panel again. What are you thinking of selling it for?
    Mar 2006
    Yuma, Arizona
    As much as I can get!
    You should go to www.lincolnelectric.com and look at the Precision Tig 275 Ready-Pak.
    I installed the advanced panel on top of that. So aside from the top end amperage, my machine has all the capabilities of the PrecisionTig 375.
    See if that is even what you are going to want and then we can talk price. LOL
    Lincoln TIG 300-300
Page generated in 1,606,606,102.09792 seconds with 11 queries
