Results 26 to 27 of 27
Thread: '98 Chevy C3500 Brake fluid leak
    Oct 2007
    Near Dayton, OH
    Re: '98 Chevy C3500 Brake fluid leak
    Last post on this issue (knock on wood). Ebrake problem...I think I slightly overfilled the master cylinder. While I'm not sure I understand how this would cause the problem, I checked the fill on Sunday and noticed it was a little too high. Guess filling it in the dark, on my slanted driveway, wasn't the brightest idea.
    Anyway, I siphoned most of the fluid out as it was still pretty dark, and re-filled more carefully. Since then, no issues with sticking ebrake light and no squeaking from brakes at low speeds.
    You'd think if this was the source of the problem that pressure in the master cylinder would have just popped the top off the resevoir.
    Regardless, thanks to all for the helpful advice. Truck's running good now, and making me money while making life easier...
    Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
    Sep 2006
    NJ, USA
    Glad it's working now.
    But if you still had 'dark fluid' still in the resevoir, I'd suggest topping off the master cylinder and rebleeding the brake system fully. Not just for any air, but at this point to bleed out any possible old fluid still sitting in the lines. Bleed each line until it runs clear.
    The best laid schemes ... Gang oft agley ...
Page generated in 1,713,288,711.52312 seconds with 19 queries
