Results 1 to 17 of 17
Thread: *update* slip on tractor forks - light/med duty
    Sebeka and Bemidji MN
    On my recent demo job I needed some forks for my tractor. Lots of heavy crap to load. http://weldingweb.com/vbb/showthread.php?t=288851
    Needed them the next day so grabbed some scrap 1.5" x 1/4" pipe, cut some plates and turned on the MM210.
    Made 3 tacks and ran outta wire!!
    Already used up all my 7014 and good 7018 and only had the son's 6013 left from him practicing.
    So these are built with 1/8" 6013 run at 130-135 amps AC on my Airco 300.
    6013....the world will probably end right?
    Pic 1 - the forks
    pic 2 - 3 pass 6013 - not perfect but pretty normal weld for me
    The top strap that bends over the bucket lip was welded on straight first, then heated and hammered over the lip. "Custom fit."
    pic 3 - chain ring for the tail
    More next post
    Airco 300 - Syncro 350
    Re: slip on tractor forks - light/med duty
    I only needed them to lift about 800 lbs, so I load checked them much higher.
    I was chainsawing the walls into 5' x 8' up to 8' x 8' sections. The 8x8 water-logged sections I could not lift one end so I know they are over 600 lbs.
    When the SA200 was up I measured about 1" flex over the length of the forks.
    Pic 1 - load check
    Pic 2 - load check
    So that was the deal in a nutshell. Needed them, made em and used em I will build real ones with rectangle tubing next time I have some extra stuff in.
    Anyone uncomfortable I used a good SA200 for a load check? LOL
    Feel free to comment - I'll start:
    "That will never hold"
    "6013 will not work"
    "Your welds need work"
    Just kidding around - as others have said, let the flaming begin
    Feb 2012
    ny
    Sweet Dave, came out nice man! I wouldn't go driving around with the SA200 on there which i'm sure you know, but for purpose cool bro!
    I hate being bi-polar it's awsome
    My Heroes Have Always Been Cowboys
    Couple extra pics
    pic 1: closeup of the bucket lip
    pic 2: chain "adjuster" from scrap and left over parts
    Quote Originally Posted by weldermike View Post
    Thanks Mike
    Ya, not going to drive around with the SA200 on those forks! :laughing:
    I'll have to remember Light/Med duty as intended.
    Aug 2004
    North Central Indiana
    Great Idea and welds.
    Thanks tackit - I try to do a good job, even when it's made from scrap
    Dec 2012
    South Carolina
    off topic. but how does the allis do with a load in the bucket? I was always curious what a tricycle tractor would handle like with a loader. and nice tractor by the way. my friend had a 53(?) wd 45
    - Christian M.
    C3 Welding & Fabrication
    - CNC Plasma Cutting
    -Mobile Welding
    -Custom welding and fab
    www.c3welding.com
    camjeep3 - With a full bucket of dirt, and a low bucket it's fine. Or stationary dumping the dirt - no problem.
    Any loads up high are SPOOKY. Lots of uncomfortable sway going on. Owned it 18 years now and it never gets less of a pucker factor with the bucket up high.
    Next reasonable wide front for sale I see, I'm buying
    It is a great yard tractor for my needs - I'm not a farmer - it will drive around the yard with a SA250 hanging on the hook (very carefully)
    Dec 2012
    South Carolina
    very cool. there was a wide front end for sale around here a while back. My friend was going to put it on his but ended up trading for a rare ford.
    - Christian M.
    -Mobile Welding
    www.c3welding.com
    Jun 2011
    Texas
    Good creativity with that chain adjuster mechanism! I'd probably do it the easy way and just use a couple of load binders. I'm starting to draw plans in my head already...
    -Ruark
    Lincoln 3200HD
    Hobart Stickmate LX235
    TWECO Fabricator 211i
    Thanks
    I needed my binders for the chaining of the load or I probably would have too
    Check out this post for a really nice set of slip on forks (post #9)
    http://weldingweb.com/vbb/showthread.php...=tractor+forks
    Those are the ones I'll likely copy when I make "real" ones for my tractor.
    *update*
    I have bent them and straightened them a few times, and the dozer mangled one immediately...
    None of the 6013 welds ever cracked, but the forks are about done for now...
  15. Likes ronsii liked this post
  16. #15
    Re: *update* slip on tractor forks - light/med duty
    Not to be ugly about it, but I'd never get near those with a ten foot pole. Dangerous stuff IMHO. Just don't stand under the damn thingsName:  t519276_scared-smiley-emoticon.gif
  17. #16
    Beautiful welds BTW
  18. #17
    Heck fire, I thought you would understand "temporary" items that you need right now - LOL
    ...but hell no, I didn't get under them
    Beautiful welds BTW
    Thanks
Page generated in 1,604,139,503.43548 seconds with 13 queries
