Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 51 to 75 of 355
Thread: Hypertherm Manufacturer Section
  1. #51
    Oct 2007
    New Hampshire, North Carolina
    Re: Hypertherm Manufacturer Section
    Tony,
    You said you had a Powermax30 on order...just waiting for UPS to deliver it. Whatever happened to that one? The T-D Cutmaster 81 is an 80 Amp plasma that is twice the price of a Powermax30. Have you really decided what you want? That's a little bit of overkill for roofing!
    Jim
  2. #52
    Jan 2006
    jim, that gouge is impressive.
  3. #53
    Mar 2009
    Oklahoma transplanted from michigan
    was ordered but it was a liquidation item that ran out the 81 is a 60 amp and I may even get a better deal or I can,t afford it at..... ya overkill for roofing for sure. 1300.00 (excellent deal Though even at that price)
    Tomorrow I hope they can get their hands on that PMX 30 for me if they don't and refuse to slash that 81 a few hundred more I'll just go to local Air gas and get the PMX 30
    I'll just have to do without the goodies and go to town tomorrow and get one could of already had it
    Lincoln 225 Tombstone,
    Miller Big 20,
    Hobart 180,150' Argon,
    A/D hobart hood
    22 Ton Log splitter,
    79 F350 dump eats 4.75 TONS and still turns
    cutters,grinders,
    And a Hypertherm POWERMAX 30
  4. #54
    Feb 2009
    Hi,
    Ordered my powermax 1250 and taking ownership tomorrow. Any recommendations on what air filters to use. I was looking at the motor guard m-26 or the hypertherm HYP128647. Any pros or cons over each one.
    Thanks
    Eric
  5. #55
    Dec 2008
    Oyama BC Canada
    Just picked up a Powermax 30 today. I was considering the Everlast or Longevity etc. but after the recent threads I decided it was to risky. Hopefully this weekend I can get set up and start cutting stuff!
    Rotavia
  6. #56
    Aug 2008
    Dansville NY
    Hi ya ec12348 I use 128647 Hypertherm Air Filter on my PowerMax 45 but it will work just as well on any Hypertherm product.
    Hi Ya rotavia congrats on the PowerMax 30 you'll find its one rugged unit and light enoght to take most anywhere.
    Hi Tony did you finally decide what you were going to purchase?
  7. #57
    Mar 2009
    Hi... Specter ya I want the Power max 30 but if they give away that TD 81, I'd have to take it but I don't think they will.
    I'll know tomorrow what's the deal with them.
    Miller Big 20,
    A/D hobart hood
    cutters,grinders,
  8. #58
    Aug 2008
    Dansville NY
    Well good luck on whatever you finally end up with.
  9. #59
    Mar 2009
    Jim (or anyone else),
    I purchased a Powermax380 new in 2005 from a welding outfit in Montana. What little I have used the machine, it has performed flawlessly. At best, I might have used it once a month.
    Saturday, while using the machine, I heard a loud crack sound and then smelled an all too familiar smell associated with electronic component failure. Naturally, when I heard the sound I released the trigger on the cutter. I noticed the AC light on the display was no longer lit, but the fan was still blowing. Sure enough, when I pulled the trigger again nothing happened.
    I unplugged the machine and proceeded to remove the cover to locate the source of the smell. After careful inspection, I found a resistor near the top edge of the Power Control Board, that had cooked.
    There is a 1/2" diameter capacitor about two thirds of the way back that is along the top edge of the board, well this resistor is directly below it. It is labeled R88.
    Anyone familiar with electronics knows that most resistors have multiple bands of colors on them that denotes the value of the resistor. Well, the middle two bands on mine are destroyed. I can see Black as the first band, and gold as the last.
    I called Hypertherm today to see if someone could give me the value of the resistor, but was told they only replace the whole board. My cost to replace the board is $845. I only paid $1029 for the whole machine. That's crazy.
    Needless to say, I would like to replace the resistor and see if I can bring my 380 back to life. If it does not, well at least I tried.
    Does anyone have a Power Control board that they can look at and tell me the color code for the resistor R88 please?
    Thank you in advance!
  10. #60
    Jan 2009
    Quote Originally Posted by lizrad999 View Post
    If you heard a loud crack noise I doubt that it will be just the resistor.
    Cheers
  11. #61
    Feb 2007
    Hamlin NY
    I'm sure Jim Colt will be along.
    I agree, its probably not just a resistor, but a cap too.
    David
    Real world weldin.
  12. #62
    Oct 2007
    lizrad,
    I am checking into the possible failure mode with our tech service group....I'm sure they will get back to me this morning.
    It is our policy to not provide schematics to board level for these units....and that policy is the same for pretty much every company that produces equipment like this. Usually components that fail on a board like this are an indication of a much larger issue..I'll get back to you as soon as I hear from them.
    Sorry for the problem....we'll try to help you get it resolved.
    Jim
  13. #63
    Oct 2007
    Lizrad,
    Ok....I was able to find you the value of those board components...the resistor, R88 is 220 ohm, and the blue capacitor, C63...is 1000 uF, 50 volts.
    The Powermax380 was produced by Miller for Hypertherm....so we do not have as much control over board components as we would with our in house built units. I would suggest replacing those parts...and looking carefully at the rest of the board for burned traces, etc.
    Often small component failures are an indication of something more major...buts it's worth a try.
    This reminds me of an old Lincoln Mig welder I had years ago....the wire feed motor would occasionally stop working, so i traced it back to a power transistor on the main board....I called Lincoln...and they would not give me the component info. I guessed on the the transistor type...found one at Radio Shack, replaced it and it worked, but within a few weeks it failed again. I suspect something else was the problem....eventually I sold the unit and bought a Blue welder!
    Keep me posted on this....I'll help any way I can!
    Best regards, Jim Colt
  14. #64
    Feb 2007
    Hamlin NY
    Mower Deck
    One rusty Mower Deck
    One Hypertherm 600
    One sheet 1/8"
    Some time and a grinder.
    I didn't know how to draw it out, so I put the deck on the sheet and traced it by reaching in through the holes I cut out.
    Real world weldin.
  15. #65
    Feb 2007
    Hamlin NY
    It fits! Just a little more trimming.
    Real world weldin.
  16. #66
    Aug 2008
    Dansville NY
    Wow david that's one of the worse looking decks I have ever seen brought back to life. Looks like you had to perform a miracle to save it.
    I just did a brush hog deck for a guy and used an heating oil fuel storage tank that we flattened with my backhoe.
  17. #67
    Jan 2009
    If you find that you need to replace the PCB make sure that you get someone to do it for you as there will be various other things to check before you bung in a new board, it may blow up as well. You cant just replace a board and power it up and "bang" test it.
    Cheers
    Billy
  18. #68
    Dec 2008
    Oyama BC Canada
    I had a brief chance to use my new Powermax30 for the first time last night.....WOW!!! Fantastic little machine. I only tried it on thin ga. so far and I could hardly move fast enough. This weekend I'll give it a healthier diet!
    Rotavia
  19. #69
    Oct 2007
    Don't be cutting all your stock up into little pieces just for the fun of it....you may need it for a project someday!
    Have fun with it!
    Jim
  20. #70
    Aug 2008
    Dansville NY
    Hi Ya rotavia I am glad to hear that you got the PowerMax 30. How do you like all the info in that manual, consumable guide, and that cd? I wish all manufacturer's had an owner's package like that! It makes setting it up and running the unit a snap.
    I have the PowerMax 45 and it still amazes me what this unit is capable of compared to many higher powered units.
    Yeah like Jim said save some of your best metal for your projects! Best Metal I have found yet is old metal bed frames!! They are excellent for making welding carts and heavy duty storage racks.
    Tom
  21. #71
    Mar 2009
    Tony,
    Jim
    Jim Hi
    Finnally after all that with air gas there is a powermax shipped out today for me so I'll be posting pics as soon as It comes of some cuts.
    no case or goodies but it wont be in the case much so i'll be happy when it's in my hands
    Miller Big 20,
    A/D hobart hood
    cutters,grinders,
  22. #72
    Aug 2008
    Dansville NY
    Glad to hear your finally going to get what you originally wanted.
  23. #73
    Mar 2009
    Hi Specter ya it's about time and I really wanted the best there is so I'm waiting
    Miller Big 20,
    A/D hobart hood
    cutters,grinders,
  24. #74
    Aug 2008
    Dansville NY
    well Tony congrats on the new baby
  25. #75
    Oct 2007
    New tool getting set up in my shop. I bought a new PlasmaCam 4 x 4 cnc cutting machine over a year ago to replace my old one that I sold. This machine has some really nice features such as fully functional torch height control and servo drives...as well as a very easy to learn CAD drawing package. I will be putting my Hypertherm Powermax45 plasma on this machine with a machine torch...I'll show the progress over the next few days....and show the first part cut! Here's a few pics so far....First pic....open the crate....then a few shots of assembly phase.
    Jim
Page generated in 1,594,635,869.65720 seconds with 12 queries
