Results 1 to 25 of 38
Thread: Tungsten Storage
    Jun 2013
    Virginia
    Tungsten Storage
    I have had a lot of problems with the plastic containers that the tungsten is sold in so I made these and they function well.
    Does anyone else have any other ideas? Please post pictures!
    Apr 2008
    NW ON Canada
    Re: Tungsten Storage
    I have a small box, sits on the bench in my shop. All my tungsten gets tossed in it.
    Jason
    Thermal Dynamics Cutmaster 52
    Miller Bobcat 250
    Torchmate CNC table
    Thermal Arc Hefty 2
    Ironworkers Local 720
    Jun 2013
    Virginia
    Quote Originally Posted by snoeproe View Post
    Yeah i had something similar but i also travel a whole lot for work and this is a little more convienient!
    Apr 2004
    British Columbia
    At home, a suitable fish tacklebox but on the job when you're crawling through the tight spots and have to carry your tungsten in your pockets.....some kind of gutted out fuse. Others will know the proper name.
    Jul 2013
    Baytown, TX
    Quote Originally Posted by Virginia View Post
    I sooooooo want one of your copper tungsten holders
    Jul 2013
    Quote Originally Posted by bullfrogg0 View Post
    I second that I need a few
    Jul 2013
    It seems weird to store tungsten in a metal container. In situations where you are carrying the tungsten anywhere, might the tungsten get exposed to whatever metal the container is made out of? Perhaps you could put some sort of rubber at the ends (to prevent contamination and dulling of the point and bottom) and maybe either some paper or foam padding inside to prevent the tungsten from rolling around, rubbing and whatever?
    I can definitely imagine a tip contaminated with copper or a tungsten covered with copper dust after jiggling around in it's tube for a while.
    As for storage, does it matter if it's exposed to the air? If so, I'd find a water/air tight container I think, maybe you could fill the container with argon, isn't argon heavier than air? Then, try to keep the container from tipping when open. Filling the container with gas would be easy I imagine.
    I don't know if any of this is accurate or would work, my imagination talking.
    Nov 2010
    s/e ohio
    I keep my cut down ones in the plastic case that carbide burr bits come in.
    If you cant fix it with a hammer, it must be an electrical problem.
    "Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
    The copper tubing works great. I use ''propress'' caps on mine. The propress cap has a ''O''
    ring inside. I think this makes a better seal. Propress fittings are joined using a propress gun tool that crimps the joint. In this case I just slid the on as a friction fit.
    http://www.bing.com/images/search?q=...electedIndex=1
    Jul 2013
    Baytown, TX
    Quote Originally Posted by bowlingonsunshine View Post
    coppe deinitely won't dull the tips. if there were somehow some contamination it would be so minute that it would just immediately burn off as soon as the arc is struck causing no ill effects/weld contamination
    Jun 2011
    Why not use a piece of PVC plastic pipe with a cap glued on one end and slip a cap on the other end. Total $ 1.49
    Jan 2008
    Richmond, Virginia
    I just stick 'em in something like this. Made one that looks like the boss.
    Syncrowave 250 w/ Coolmate 3
    Dialarc 250, Idealarc 250
    SP-175 +
    Lincwelder AC180C (1952)
    Victor & Smith O/A torches
    Miller spot welder
    Quote Originally Posted by kctgb View Post
    Too cheap, larger then copper, not as fancy. Kidding, that will work fine too.
    Dec 2009
    Stevens Point, WI
    This is my box.
    Around here, for away from the shop jobs, I've seen several of the the journeyman union TIG welders who have made tungsten holders out of SS tube about 8" long and about 1 inch in diameter,with a cap that has an end that is a quarter or nickel welded onto the SS tubing. The cap attaches to the SS tube with a threaded fastener. It's a cool looking setup. They get the SS tubing from their work in clean rooms or sanitary welding jobs...
    In the shop, I have a plastic divided box much like the ones shown above, but bigger.
    Sep 2010
    China
    I use this it has 2 tier storage, the top storage is long boxes which is perfect. then I use the bottom storage for all my collets and gas lens, the cups fit on the right side in the pockets, and the back caps and insulators sit in the misc bottom square
    keeps everything nice and organized. you can adjust the sizes of the squares with the dividers.
    http://www.academy.com/webapp/wcs/st...le+box&Ntk=All
    Miller Maxstar 200 SD
    Piperliner #10 Gold
    Jun 2013
    Northwest Arkansas
    Just about fell off my chair laughing. I don't need another project to work on, but I'm thinking that having one of those on my tool box would look pretty cool-especially with sharpened tungsten sticking through it. Lol
    Sent from my SGH-T989 using Tapatalk 2
    Feb 2013
    Cleveland, oh
    I have a plastic box for cups, collets etc. altoids tins for tungstens
    Jun 2013
    Virginia
    Make one! you can get all the supplys at lowes!
    Jun 2013
    Virginia
    i havent seen any pvc that would be small enough!
    Jun 2013
    Virginia
    i use a very organized box for my tig set up at home but these are just so hand for traveling! they are a little bigger than a pen and they just seem to fit so well in my pocket!
    May 2013
    Virginia
    A few clever ideas here. I might consider trying one out myself.
    For now I still use the plastic box they come in.
    Dec 2012
    Woodstock, Ga
    Quote Originally Posted by dcoffmanjr View Post
    That one hit me the same way, very funny and soooo practical
    Magazines have issues, everything else has problems
    Jun 2013
    Virginia
    HaHaHa! just think if a employer walked by and you were pricking the doll! They would stay far away! where in VA are you from?
    Jan 2008
    Richmond, Virginia
    I'm in Richmond, more or less.
    SP-175 +
    Miller spot welder
Page generated in 1,713,257,324.85615 seconds with 18 queries
