Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: man not again
    Aug 2008
    Re: man not again
    [quote=duaneb55;278223]
    Quote Originally Posted by 19662 View Post
    More of a concern with external wire feeders than enclosed ones 19662 but. . .
    lube on the wire = lube on the drive rolls = pick up dust and particles = transfer of crude to wire = dirty liner. As for just keeping the wire clean - foam ear plugs. Stick the wire through one and let it run up against the wire guide.
    I figure if welder manufacturers thought their gun liners needed lubrication they would have equipped the welder with a wire lubricator from the start. Just my opinion.
    Pretty much my sentiments. Plus there's a certain amount of lube already on the wire straight out of the factory
    All I ever have to do is to take the liner off the machine, and blow it out with compressed air from the gun end. Amazing how much crud comes out. I think a lot of it would stay in the liner if you added oil to the mix
    http://www.farmersamm.com/
    Nov 2008
    spring valley ohio
    Re: man not again
    well its a sad day for me and all the welder across the world. my parts came in and ther wrong well one is .insted of a drive roll i got a plasma air filter
    Aug 2008
    Re: man not again
    That sucks
    Nov 2008
    spring valley ohio
    Re: man not again
    yes it does but on the up side its working again. pulled it all apart and cleaned the old linner out and bam. she back up and weldeing.so i keeping the new linner and when the new drive roll comes in i will put that in.its crazy how much stuff can get in that linner
Page generated in 1,713,295,528.80686 seconds with 17 queries
