Page 1 of 4 123 ... LastLast
Results 1 to 25 of 95
Thread: 09 wrangler one ton build
    Oct 2012
    Sacramento, California
    After finding a pair of 14 bolt axles, for cheap, I was planning a Dana 60/14 bolt build.
    But, a buddy/Benefactor NIXED that idea.
    So now its a 14 bolt rear/steering 14 bolt front
    This build will be documented, on several forums.
    budget build to start, but with future upgrades in mind
    To start, disk brake conversion, Detroit rear locker, Yukon Zip Locker front(selectable air locker), 5.13 gears, shave kit for both, and factory style 4 link suspension.
    Future= selectable rear locker, double triangulated 4 link rear, triangulated 4 link front, and coil over shocks
    Arizona
    Re: 09 wrangler one ton build
    We're gonna need to see some pics
    Miller Challenger 172
    Miller Maxstar 150 STL
    Victor 100C
    Victor Journeyman
    Oxweld OA
    Harris O/A
    Smith O/A little torch
    No, that's not my car.
    Sep 2005
    Cave Creek AZ
    I'm gonna, and here are some pics are two different animals, I'll wait for the picture show.
    Oct 2012
    As soon as axles are confirmed as mine, pics will come.
    This project is insane, and will probably kill me.
    Apr 2012
    I'm assuming you can get reverse cut gears for at 14 bolt? I know you can for a Dana 60/70... My only gripe with a 14 bolt is you can't remove the yoke without risking your pinion preload, Dana is a much better setup in that sense IMO.
    Bruce
    Apr 2013
    NE Florida
    Quote Originally Posted by Bruce Avison View Post
    Bruce
    Just switch the crush collar for a solid spacer and shims.
    OP, need some pics. What are using for knuckles? Dana 50 parts?
    Oct 2012
    Chevy kingpin 60 is going to be the donor axle, but I am leaning towards a balljoint axle. For ease of trail repairs.
    Apr 2013
    NE Florida
    Quote Originally Posted by Fnord5 View Post
    Kingpin is easier for trail repairs as you can remove and replace the kingpin bushings and springs without a press. You just need some longer bolts to pull the cap down and compress the spring. Ball joint requires a ball joint press or a hydraulic press. However if you want to go ball joint definitely look for Dana 50 axles. The outers are the same as the Ford Dana 60 and the axles can be had for cheap because they are not worth anything due to the center section.
    Sep 2008
    SF bay area, CA
    Not going with axle tech portal 14 bolts?
    Oct 2012
    Budget build. LOL.
    Oct 2008
    New Jersey (yeah it sucks)
    Exclamation Re: 09 wrangler one ton build
    Pictures please......
    What size tire are you going to run???
    Is this going to be a trailer queen?
    Suspension???
    Oct 2012
    Quote Originally Posted by Billdacat View Post
    Suspension???
    Still haven't heard if my buddy got them, he's a busy guy and is up in the mountains often.
    Tire plans are recentered military beadlocks and 37" tires(Humvee take offs)
    Suspension will be the stock style 4 link that I am running now, it has DOM control arms and currieenterprises Johnny Joints and 4" currie springs.
    Daily driver for sure.
    Oct 2012
    I got my front axle finally.
    This will be my front, I'll cut it down for the short side, inner sleeve and an extension for the long side.
    Pics to come as I tear it down and start work.
    Nov 2011
    SoCal
    14FF in the front?
    If so that's awesome overkill for a Jeep. I like it.
    Aug 2009
    Atlanta Ga
    want to buy an ARB locker for the 14 bolt never used $600.. =D
    Oct 2012
    Quote Originally Posted by socoj2 View Post
    Part number? Just need to make sure it works with the gears I want to use.
    Aug 2009
    Atlanta Ga
    arb-rd114
    Oct 2012
    If we can work out a payment plan, I'll take it.
    Oct 2012
    Hmn....pinion appears to possibly be a bit stronger.
    Ring looks different too....
    Oct 2012
    Empty, ready for a deep clean then cutting.
    Oct 2012
    No new pictures, but some updates.
    Picked up a set of kingpin knuckles/hubs/spindles for the front, need a total rebuild(expected) but should work just fine.
    They came off a 1988 Chevy 3500 dump truck.
    Sourced my rear axle from a buddy, military 14 bolt, 4.56 gears, Detroit locker, disk brake conversion, great lakes offroad diff cover(1/2 thick ring, 3/8 cover) and a smaller style truss.
    Only 5000 miles on it.
    Need to re-tube the front housing, and start fabricating my control arms.
    Also doing a 4" front, 8" rear stretch, with all new control arm joints.
    Jan 2006
    How do you keep the oil in a steering conversion? I know most steering axles like the Dana 60 have oil seals inboard of the tubes but the 14 bolt being a rear only has the seals on the ends. The 14-bolt is a bad *** axle after you trim the excessive overhang off the bottom. I really don't know why Chevy went to the US Gear 11.5 inch on their diesel trucks (same as Dodge which nobody should emulate) because the 14-bolt is basically the strongest there is. How big of a tire do you plan to run? 37 inch seems to be the best for most every situation road and trail. My friends and I built a rockin' 4Runner on 33's that could do basically every trail Hollister Hills had to offer short of jungle trail and that was on 33" tires. The key is flex but keep it low. We started at 6 inches of lift but ended up dropping the rear to 4 with the 53" Chevy leaf springs.
    Oct 2012
    You add seals at the pumpkin, its not perfect, it will leak a little from what I hear.
    As I'm set up now, with 32's I can do the whole Rubicon fairly easily, and I'm unlocked.
    I'm not adding any lift(5" now) just going long arm Now, and coilovers in the future
    The plan is 37's for now, maybe 40-42's in the future.
    Oct 2008
    How do you fixture your steering knuckles for welding. Control arm brackets??? Pinion angle and castor????
    On the subject of seals...You are going to need a vent for the pumpkin if your seals are moved inboard...
    Keep us posted.
    Oct 2008
    deleated
Page generated in 1,603,163,016.04139 seconds with 11 queries
