Results 1 to 15 of 15
Thread: New guy's not-so-new projects
    New to the forum so I thought I'd share a couple quick pictures of some shop projects...
    A bench built for my mom, based on a picture she took of one that she liked
    Cutting station and metal rack to conserve shop space... Not quite finished but just haven't had the time. I want to make a rear fence and an adjustable stop for repetitive cuts.
    I'm sure there are more pictures somewhere, but that's all I can find at the moment.
    Dallas, Tx
    Re: New guy's not-so-new projects
    I like the layout of your cutting station and I love the bench.
    Mar 2012
    Southern Maine
    I think i'd like to see more of that sweet building! More pics...if you can? Oh, yea..killer bench too...
    POVERTY...is the Mother of Invention
    Millermatic 211
    Millermatic 140
    Miller Thunderbolt XL
    ArcOne 100STS inverter w/TIG
    Thermal Dynamics 38XL
    Victor Oxy/Acetylene
    Jancy Slugger Holemaker II
    Jet 5x6 Bandsaw
    Never enough time & sleep.
    Aug 2010
    Guelph, Ontario, Canada
    Nice set up, like the conduit drops, keeps the tangle of cords under control I assume?
    You build the station on an existing rack, or make that too? Looks excellent.
    South Central Kansas
    Really like the Bench, are you going to paint it?
    May 2007
    SoCal
    Ah, very nice cutting station and good storage space. See, that's how it needs to be folks!
    Welcome aboard!
    Job 28:1,2
    Danny
    Feb 2012
    ny
    Great stuff bud! My mother would love that bench, she's been asking me to build her one. Thanks for the reminder. How do you like your quansit building? Iv'e been looking into them and like them!
    I hate being bi-polar it's awsome
    My Heroes Have Always Been Cowboys
    Thanks for the kind words...yes, we'll paint the bench, but she needs to pick a color first.
    Mike: The quonset was on my property already, so I'm just trying to make the most of it. All in all, it can be made to work pretty nicely. The only downside is that there isn't really a good way to insulate them (which is an issue with Canadian winters). If I were starting from scratch in this part of the world, I'd probably go with a different design, but I can see them being very economical in a warmer climate...just make sure you can get lots of airflow in the summer and it should be nice to work in.
    Aug 2010
    Spray foam insulation has been a common insulation method near me, not real cheap, but it is fast and easy the biggest problem is that then you have to put tin or fireproofing on the areas where you weld.
    Quote Originally Posted by mammaogi View Post
    Yes, I built the rack to hold the cutting station...Name:  Photo2476.jpg
    Do you have any details on how the fireproofing is fastened? I would be curious if I could make this work, but suspect that the cost would prohibit it at this point.
    Nice. Like the rack set up too. Ma will be happy for sure. Next she will want one that's swings or rocks.
    Here's some sites about insulation.
    http://www.insulation4less.com/Insul...tructions.aspx
    http://www.insulation4less.com/Insul...nsulation.aspx
    http://www.practicalmachinist.com/vb...ilding-208738/
    Aug 2010
    Guy I used to work with, (no pics sorry) took out a couple of the bolts in his Quonset about every 8' and replaced them with longer bolts to hold a bracket that he then attached 2X6'S to as studding, had the spray foam done, and then skinned that with old roof tin behind his hot saw, and plywood everywhere else. He only went up about 6' but it made it easy to fasten task lights and electrical to the plywood. It was a process, did the 2X6's everywhere, and the foam. Then as time and money allowed did the tin and or wood. Hope that explains it clearly enough. M.
    Aug 2008
    Hey, I saw this the other day, and forgot to say anything about it
    Awful nice thing you made there.
    I like the rollers a lot. I made a cut station, and didn't use rollers (although I'm not sure the roller bearings would hold up outside in the weather), and I'm telling you............the rollers sure would make it easier to slide heavier tubing etc. than my solid bars It's not a killer, but annoying sometimes when you have to just move the stock a smidge to line up the cut mark with the blade IF THE STUPID STOCK IS 20" LONG
    Have you banged your shins on the lower material racks yet??????
    http://www.farmersamm.com/
    I've been off the grid lately, as things have been busy. Thanks for all the replies and suggestions, I'll definitely be looking into the insulation options more. I'm attaching a couple of pictures of the rack that I built on my TA 252i. If anyone can gain any ideas for you own use, feel free. And as always, feel free to criticize or make suggestions. Crappy cell phone pics:
Page generated in 1,610,856,228.21370 seconds with 14 queries
